Results 1 to 9 of 9
Thread: Headlights D.O.A.
01-30-2012, 03:45 PM #1Newbie
- Join Date
- Jan 2012
- Posts
- 4
Headlights D.O.A.
A few weeks ago my headlights started turning off and on while I was driving at night, now they don't work period. I asked around and was told check the bulbs and the "dimmer switch" the bulbs looked good and I installed a new dimmer switch this morning but my headlights still won't come on!! All other lights work good and function normally. Any ideas are greatly appreciated... My truck is a '93 Chevy
01-30-2012, 03:59 PM #2
Check all of your relays, check the switch as well (they can get to hot and cook off) also your wiring harness etc.. Basically if it is connected to the headlights check it out.
Mike
Currently
1997 Chevy S-10 Blazer 4X4 with 330K miles and counting (Hunting rig).
2009 Saturn Aura XE (wifes car)
2011 F-150 Crew 4X4
"Hold it to the floor till you see God.... Then Brake!!!!"
01-31-2012, 03:05 PM #3
The headlamps going off and on is usually an indicator that the headlamp switch is bad. Did you check for voltage at the dimmer switch when you replaced it? Was the connector melted or deformed? I'll bet you've got a simple, old fashioned bad switch.
Good Luck and God Bless
01-31-2012, 04:00 PM #4Newbie
- Join Date
- Jan 2012
- Posts
- 4
This sounds stupid but you do mean a new headlight switch as the one on the dash?! I didn't check any voltage just replaced the dimmer switch.
01-31-2012, 07:49 PM #5
common for the headlight switch or the high/low switch to fail like that on the 88-94 interiors, if you don't have headlights at all then its most likely the headlight switch on the dash.
be carefull with the dash bezel screws through the switch, the posts for the screws like to crack really easy causing the switch to fall in when you push on the switch.Last edited by outalne94z71; 01-31-2012 at 07:52 PM.
my 88 sas "mudwasp"
88 chevy k2500, started as reg cab lb, now reg cab shortbox, sas 17'' of lift, 52'' front springs f.i. bbc , 79 dana hp 60 chevy outers, 14bolt ff spooled divorced 205 and cut 40'' gumbos
1998 k3500 gmc crew cab dually L65 6.5TD 4l80e with a couple of mods
bouncing truck avatar creator
01-31-2012, 07:55 PM #6Newbie
- Join Date
- Jan 2012
- Posts
- 4
Just ordered a new switch hopefully that's the problem, thanks!!
02-01-2012, 09:47 AM #7
Yes the main switch on the dash. I see you have ordered a new switch, but be sure to test the wiring where it connects to the switch before you replace the switch.
02-03-2012, 02:56 PM #8Sr. Apprentice
- Join Date
- Jul 2011
- Posts
- 36
yeah i had the exact same problem in my '92, The switch burned up and was actually smoking inside the cab...talk about scary lol
02-05-2012, 03:24 PM #9Newbie
- Join Date
- Jan 2012
- Posts
- 4
it was indeed the headlight switch. ive owned the truck a little over a year and the high beams have never worked. funny thing changing the switch brought them back to life!! haha thanks for the help!!
Similar Threads
No headlights? Help Please!
By Magna86 in forum Chevy Truck AccessoriesReplies: 2Last Post: 04-06-2011, 10:22 PM -
Headlights
By phathoe02 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)Replies: 4Last Post: 09-24-2009, 07:59 AM -
new headlights
By zackyv55146 in forum Photo & Video GalleryReplies: 9Last Post: 05-12-2009, 09:11 AM -
Headlights
By raiderman8112 in forum Chevy Truck AccessoriesReplies: 3Last Post: 08-27-2008, 09:37 PM -
Headlights
By redstripesilverado in forum Photo & Video GalleryReplies: 21Last Post: 08-19-2008, 01:22 PM
Bookmarks
