Results 1 to 10 of 11
    Default '90 accessory won't work?
    The key won't turn back, so I have to put it foward and drain my battery even more. What's up with this?
    It seems to be a fiarly common problem in Chevy steering columns from say, 88 to 91 at the least. I had the exact same issue in my 91 suburban before I replaced the sterring column, and by association, the ignition cylinder and such. My best friend's 88 S-10 blazer had the same issue. I'm not 100% sure where the problem lies, but it almost seems like the rods going down the column to the ignition switch bind up or something. It's quite annoying. Luckily, when I replaced my steering column, the accessory position worked in the new column. Hit or miss I guess. If you find a solution, I wanna know though
    Christopher
    How worn is your key? was the lock ever replaced? goto a lock smith and get a key cut to code not a copy of your key and see if that makes it work. do you have a factory key for the lock you can try it but not a copy of a key....this is a copy of a worn key and it gets worse on each copy....mike
    Michael Collins
    1993 4X4 Suburban
    many other toys as well
    I figured that was the case. The dumbass I bought the truck from had two sets of the most worn keys I've ever seen. Should I just replace the locks or will new keys be adequate?
    Former Member
    Oct 2007
    Huntsville, Alabama
    Quote Originally Posted by trenchwarfare View Post
    New keys will be fine, and less expensive as well.
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Makes me wonder. My accessory position has never worked on my 93. I'll let you know what I find out.
    High Desert SoCal
    02 Honda Civic LX
    Does this vehicle have a tilt wheel?
    I ask because I had a similar problem with our 79 plow truck. The tilt wheel just flopped in the breeze.
    My problem was a broken column after years of jumping in the truck holding onto the wheel.
    But it can be something as simple as moving the wheel, column up and down while turning the key.
    And one Big Pain in the Ass When it Doesn’t.
    See a Pattern yet?
    Quote Originally Posted by 84fiero123 View Post
    It does have a tilt wheel. I'll have to try that too. How do i find out what key I need to have cut?
    Former Member
    Oct 2007
    Huntsville, Alabama
    Drive it to a locksmith's shop. Tell them you lost the keys and you need to have new keys made. Sit back and see how long it takes them to figure it out...
    So I'll have to wait to get it legalized? Windshield, inspection, registration, insurance, and a few other things to do before I'll be driving it.
  1. 2002 Suburban Accessory Power
    By suburban_atlanta in forum GM Electrical Tech
    Last Post: 03-31-2010, 09:52 PM
  2. WANTED: 7.4L vortec accessory brackets
    By Looey in forum General Classifieds
    Last Post: 11-09-2009, 10:21 PM
  3. How to provide more accessory electrical power?
    By rfdillon in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-06-2007, 10:57 AM
  4. accessory belt comes off
    By 94VERTiGO in forum GM Powertrain
    Last Post: 07-17-2007, 06:46 PM
  5. Favorite switched accessory lead??? Anyone?? [Expired Topic]
    By MN_Burbon in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-25-2005, 10:42 AM
