Results 1 to 2 of 2
    Default Steering Stabilizer
    I have my truck sitting stock right now but when I get it lifted (probably 3 inch sus) I want to put a steering stabilizer kit on it. My question would be to do this before a lift or after a lift? I have some shimmy in my steering and I think the description says it'll take some of the shimmy out.
    But this could all be put on hold since someone wants a new "set of clothes"....thanks @GMCErica
    Current:
    Future:
    i really dont think it would matter to be honest... but if it were me i would probably wait until after the lift, just to be on the safe side in case any happens to change for unknown reasons, but i will add that yes a steering stabilizer will take away "some" of the so called shimmy, but consider it a bandaid for the shimmy. if you have steering shimmy you have another problem that needs tending to, i would say before you do the lift and steering stabilizer. i have heard plenty of people who said a stabilizer took their shimmy away and they were happy, and if thats what you are comfortable with, more power to you, but if you want your front end to last longer i suggest finding the culprit for the shimmy first.
    ball joints, tie rod ends, inner tie rods, rack-n-pinion (if applicable), anything else steering related either check or replace
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  1. 2wd 97 chevy silverado, steering stabilizer ?
    By Blue97chevy in forum Lifted & Offroad Suspension
    Last: 09-02-2011, 03:39 PM
  2. steering stabilizer
    By reggiecab2000 in forum Lifted & Offroad Suspension
    Last: 07-06-2011, 10:17 AM
  3. chevy express steering stabilizer
    By hardybob in forum Lifted & Offroad Suspension
    Last: 05-26-2010, 10:00 PM
  4. Steering stabilizer bolt woes - need help
    By Rocketron in forum General Chevy & GM Tech Questions
    Last: 01-26-2010, 06:21 PM
  5. Steering Stabilizer??
    By canislupis69 in forum General Chevy & GM Tech Questions
    Last: 07-01-2009, 07:21 PM
