    Default Truck won't start after it warms up.
    I'm thinking of buying an 84 chevy 4x4 from a friend of mine. He says it runs fine but when the engine gets warm and you turn it off, it won't start back up. Once it cools down, fires right back up. Any ideas?
    Sep 2011
    houston texas
    i had an issue like this before with 89 1500. it ended up being the ignition coil. look for a small crack on it anywhere or check the resistance.
    Ok I'll check that out. Thanks.
    ---------- Post added at 05:50 PM ---------- Previous post was at 05:08 PM ----------
    Ok update: Asked him some more and he said it won't even turn over when its warm but will start if you jump it.
    Quote Originally Posted by madmatt6988 View Post
    does this truck have headers on it, sounds like heat soak in the solenoid.
    my 88 sas "mudwasp"
    bouncing truck avatar creator
    No headers, but my friend said he thinks it's the starter. I thought I'd get some advice before buying parts here and there till its fixed.
  1. Speedometer works when cold and quits when truck warms up
    By brickhead11 in forum Chevy C/K Truck Forum
    Last: 01-27-2012, 08:51 PM
  2. car wont start when it warms up!!
    By chancek31 in forum Chevy Camaro Forum
    Last: 10-26-2011, 12:31 PM
  3. Replies: 6
    Last: 05-25-2011, 08:46 PM
  4. truck won't start
    By firecapt44 in forum General Chevy & GM Tech Questions
    Last: 06-04-2010, 09:50 AM
  5. Truck Won't Start
    By GymRat in forum General Chevy & GM Tech Questions
    Last: 05-29-2009, 09:00 AM
