    Default New Member!! Skid Plate - Need one!
    Hello GMTC Forum folks!
    Yes, I am new and PROUD OF IT ha!
    Ok.. So, I have this "New to me" fully stock 1999 GMC Suburban SLT k1500 w/ a peppy 350.. Picked up recently with less than 90,000 miles on it! BUT, the previous owner tossed the skidplate.
    I am in the market for a frame rail to frame rail style skid plate, or something that would cover enough junk under the truck so i am comfortable..
    I would like to protect:
    1. Front Dif
    2. Oil Pan
    3. Transmission pan and xfer case
    Any ideas? I am considering building my own but would need to replace my defunked welder first.. so if cost of building is less than the cost of buying i willl be building
    Many thanks to those out there that have to read my above post! for putting up with a new guy!
    Mark
    I would look at a local salvage yard. If there is a pull-a-part near you then you might be set. Then you could just pull one off of another 1999. You might want to measure, but I am pretty sure that the plates from a z71 would fit. It might require some drilling and tapping for mounting if the holes are not already there. Alternatively, you can check out GMpartsclub.com here are some prices I came across for a 2001 truck. They will not fit yours, but it should give you an idea. The prices are not that bad.
    GM PART # 15843753 Aluminum Skid plate protecting oil pan
    GM LIST: $39.24
    GM PART # 15049809 Aluminum skid plate protecting transfer case
    GM LIST: $32.97
    i second the salvage yard. you find these trucks in there allllllll daaaaaaaaaay loooooooooong
    bob seger sold millions
    like a rock
  1. Skid plate for a 6" Fabtech
    By jmanb in forum Chevy Truck Accessories
    Last Post: 12-19-2011, 05:42 PM
  2. skid plate
    By Burden33 in forum Chevy Truck Accessories
    Last Post: 06-11-2010, 07:38 PM
  3. FS: 08 Z71 front skid plate and shocks/struts
    By aftriathlete in forum General Classifieds
    Last Post: 05-06-2010, 10:11 PM
  4. ideas for front skid plate for Silverado?
    By kawasaki_kid in forum Chevy Truck Accessories
    Last Post: 01-28-2010, 10:32 PM
  5. fuel tank skid plate
    By Bill B in forum Chevy S10 Forum (GMC Sonoma)
    Last Post: 07-08-2008, 09:58 AM
