    Default rear brakes on 2003 suburban
    So the lining fell right off my pad on my rear brakes of my suburban. When I changed the pads I noticed that the piston went in pretty hard. is there really a good way to clean these up and lube them real well so they will operate smooth? I was told by a neighbor that he usually takes the pads off and get the piston to come out a good distance, put some never seize on it and then use the c clamp to put it back in place…hopefully that will lube it all up good. Makes sense to me. Trouble with my neck of the woods is we have a lot of salt/sand and grime on the roads in the winter and it gets into everything…creates quite a mess. Is this a good idea to do it this way, I'd rather not buy new calipers if I didn't have to.
    89 chevy stepside off road
    03 suburban Z71
    03 Yukon SLT
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    I would be very reluctant to try to reuse that caliper and here's why...If it was hard to push back because of corrosion then the dust boot has failed and the seal WILL now fail and soon. Probably not a catastrophic failure with complete loss of all braking but the ability to stop has saved my butt way more often than the ability to accelerate. Do yourself and your loved ones a favor and replace it. At the least rebuild it and if you use an antiseize then get a high temp formulation, no grease.
    Sr. Engineer ahm1127's Avatar
    Pennsylvania, United States
    dpeter gave you some great info
    Everyday I wake up is a great day! ;-)
    05' Chevy Suburban, 11' Ford Fiesta
    ...sometimes a need a good kick in the butt, I don't know what I was even thinking..... I pulled the brakes off again and checked out the calipers. one piston was sticking so bad that it wouldn't even come out when there was no pressure against it. so for $56 each and a couple hours time I went to advanced auto and bought a couple of new calipers. now, for 100 bucks I've got a brand new rear brake system on the old girl, and the piece of mind to know that I can stop when I need to.
    and I agree, the need to stop is more necessary than the need for speed. thanks for the advice guys.
    Quote Originally Posted by kennyb79 View Post
    That $100.00 you spent is far cheaper than anything that could have happened to not having your brakes work correctly.
    Get the Gorilla!
    gorilladip.com
    sales@gorilladip.com
    Congrats on a job well done!
    I know this problem is fixed but It would be a bad idea to push out the piston almost all the way out and put on anti seize. Behind the dust cover is a square type o ring. About 15 20 years ago most everyone rebuilt their calipers. A garage would rather replace than rebuild as well. But now I don't think you can buy a
    rebuild kit, well maybe at Napa. I would just rather spend the money and get a lifetime guarantee on them. In order to rebuild take a rag or rags and stuff between the piston and side of the caliper and lighty blow air through the brake hose hole until the piston pops out. Then you clean up the piston and make it nice and smooth again, clean the inside of the caliper replace the o-ring, dust seal, put some brake fluid on the piston (as lube) then slowly push piston back in.
    "If it ain't one thing, it's a mother******g nother"
  1. 2003 Suburban - Would like to elimitate my rear air contols
    By jimweee in forum GM Electrical Tech
    Last: 04-07-2010, 05:10 PM
  2. 2003 z71 Rear Brakes
    By gaborn73 in forum Lifted & Offroad Suspension
    Last: 09-28-2009, 09:30 AM
  3. 2003 z71 Rear Brakes
    By gaborn73 in forum How-to Guides
    Last: 09-23-2009, 11:11 PM
  4. 04 Suburban 1500 front and rear brakes/rotors the same?
    By skidork in forum Lifted & Offroad Suspension
    Last: 05-20-2009, 10:11 AM
  5. 2003 Tahoe - rear shocks and brakes
    By Saleen2005#14c in forum Lifted & Offroad Suspension
    Last: 04-03-2009, 08:16 AM
