Results 1 to 10 of 17
    Jr. Apprentice Blue97chevy's Avatar
    Jun 2011
    Bullhead City, Arizona, United States
    Default Rough Country 2" lift coils and 4" lift spindles
    97 silverado 2wd and Im trying to find some feedback on this setup but have not found anything.. Is anybody using this as a lift ? all i can find is threads of people using spacers but i need to buy coil springs soooooo.... and if you are using this, pics and tire size would be great..
    Im currently on a Fabtech 7.5" 0n 315/70/17 but want to drop it down a bit and run some 33/12.50/15 on 15x10 mickey thompson classics
    Anybody?
    Go Green Bay!
    I have a 96 2wd and I'm running the 4'' Rough Country lift. I installed it myself and it really wasn't hard at all.I do not have the 2'' springs just the 4'' spindles. I am running 32 11.50 Maxxis mudder buckshots. When I first did it all I heard was that these old body Chevy's are bad about rubbing on the back of the fender well so i wasn't sure what size tire to run. they recommend 31's with the lift I bought but knew I had plenty of room to fit 32's
    2000 Chevy Silverado 4WD Classic
    2'' lift Torsion Keys and air shocks
    33/12.50 Hankook Dynapro M/T
    3 1/2'' down pipe back 6" Tip
    Dodge Towing Mirrors
    Smoked Tails, Cab Lights, and Side Marker Lights
    1% Rear and Side Window, 20% Front Tint
    American Racing Wheels/ With a custom black paint
    Cold Air Intake
    Edge Performance Chip
    Custom Audio System
    LED Tails
    Black background headlights and parking lights
    Jun 2011
    Thank you for your response, I need to buy springs one way or another but if i need the extra lift to clear the 33's on a 10" rim then im looking to see if this 2" spring will be enough... Im running on a 7.5" lift now with 17x9 Moto metal wheels and 315's and still rub after trimming.. Im really wanting to get away from that because its annoying , i might aswell have a lowered truck.. (lil Sarcasm)
    Im probably better off going with a 15x8" wheel and run 32's and that Sucks............... the pic above, is that your 96 with the lift spindles
    Go Green Bay!
    Yes that's my 96. Those are factory wheels on my with the centers painted black but the 32's mount up nice and then i have 1 3/4'' spacers in the rear to match the front. that rough country lift offsets the tires like a true 4wd is.(To give it that same stance, but i like when they are all the same) Well ill give you a somewhat of a reference, my friend has a 98 2wd and he has a 3'' body lift and the rough country 4'' spindle and his 33x12.50's still rub.
    Cold Air Intake
    Custom Audio System
    LED Tails
    Jun 2011
    Yeah, thats a good looking truck. I think i might just throw these 15x10's on craigslist and go buy a new set of 15x8. i know i will be good then , and the 32" tire would be fine. it would look ghetto on a 10" rim..
    Go Green Bay!
    Yeah that little skinnier wheel will stand that tire up a little more. I think you will be happy with it. On my 2000 classic I went with a little wider stance. I can post more pics if you'd like to see the 96 from different angles
    Cold Air Intake
    Custom Audio System
    LED Tails
    Default Rear Lift Block Question
    Do you mean no 2" block in the rear instead of springs? So out of the entire kit you just used the 4" spindles and longer shocks? Please give fender measurements before and after if you have them. http://www.roughcountry.com/gm-suspe...kit-231n2.html
    I'm thinking about just buying the spindles and maybe Bilstein 5100 shocks if you don't need rear blocks.
  1. Replies: 14
    Last Post: 02-12-2012, 12:07 PM
  2. 1977-1991 4WD Chevy 1/2-Ton 6" Rough Country Lift Kit
    By parts bot in forum Chevy Accessories eBay
    Last Post: 11-15-2011, 09:10 PM
  3. 77-91 Chevy GMC 4WD 4" Suspension Lift Kit Rough Country
    Last Post: 11-14-2011, 09:00 PM
  4. Rough Country 4.75" Combo Lift Kit
    By Fonze in forum Lifted & Offroad Suspension
    Last Post: 10-20-2011, 02:37 PM
  5. rough country 3" lift
    By tmcroc24 in forum Lifted & Offroad Suspension
    Last Post: 01-21-2010, 12:50 PM
