Results 1 to 10 of 11
    Default 305/60R18 on a RC leveled '11 Silverado rubbing?
    I just installed a Rough Country 2" leveling kit on my 2011 Silverado and already have a set of the Helo 835 rims for a new set of tires. My question is could I install 305/60R18 Nittos on these rims without rubbing issues? If I do get rubbing what can be modified or location of anything or isn't the rubbing really that bad? Anyone have experience with this tire size and a leveled truck?
    I got those size tires on a ccm 2.5 level and I only rub in reverse at full lock and I just let it rub till it fixed it self aka rub about a piece of the wheel liner
    2009 chevy 1500 z71 4x4
    Sr. Apprentice CobraAviTek's Avatar
    Feb 2012
    New Bern/ Havelock, NC
    Subscribing because I've got a 2.5" level and am interested to hear any info that comes from this.
    Ok that's good to I know I found nittos in 305s for cheaper than 285s an figured why not
    Go bigger than. I will have to consider it then. Was it rubbing plastic or metal?
    Just plastic and only a ill bit
    what offset on rims u have? i want the 305 to stick out a little. i believe i want a zero offset or a little negative offset for the look i want.
    I will kinda be in the same boat once I buy my truck. Wondering if I can with RC 2" level kit on the 08-13 body style run 285-65-18 trail grapplers with no rubbing? Also to make sure a positive offset would stick the tire out farther and a negative offset would tuck the tire in correct or do I got it backwards?
    I installed 305/60/18 Dick Cepeks on factory wheels and I have no rubbing, with 2.5" level kit. After market wheels should have the same offset as OEM, IMHO. My tires don't protrude much at all. Check my garage for pics.......
    Nice looking truck man! Thank you, looking on tacoma world looks like those are pretty close to same as 285 65 18 so i should be able to fit them on there I am guessing. Looks like the stock offset from what I have found is +25mm can anyone verify this just to make sure? Some of the rims I have been looking at are +18mm thinking that is pretty close if so.
    Most chevy stock wheels that I remember is +31 so +25 is close. But with those tires and +18 you should be good.
    2002 Chevy Silverado & 1995 Ford Bronco
    02 Silverado: 50K miles, 20" Motto Rims, Flowmaster 50 Series
    95 Bronco: 160K miles, 4" Superlift, 33/12.5/15 Mickey Thompson
    01 Civic: 75K miles, DD
    -Erik
  1. lets see some leveled Silverado 1500's
    By wheeler32686 in forum Photo & Video Gallery
    Last: 06-20-2012, 07:07 PM
  2. 07 NBS leveled and rubbing....
    By Adam in forum Lifted & Offroad Suspension
    Last: 07-29-2011, 03:05 AM
  3. 09 Silverado grinding/rubbing noise
    By nxconvict in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-05-2011, 11:07 AM
  4. stock vs leveled 2008 silverado
    By chschevy58 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-22-2010, 03:43 PM
  5. new tire setup 320/60r18
    By rurdy in forum Member Introductions
    Last: 09-11-2008, 08:47 PM
