Results 11 to 20 of 30
    Can you put the add a leaf in without removing the whole leaf spring pack?
    Hey bro, have you already purchased your type r subs?
    ---------- Post added at 10:59 PM ---------- Previous post was at 10:38 PM ----------
    was just gonna say that with my box from subthimp I didn't have to buy shallow mounts.. i've got two standard r-10's stuffed under my back seat.. granted, my truck IS a crew cab. but you might compare the two boxes.. it took some finagling but they are definitely in and they sound AWESOME!
    "Truck Norris"
    - 2008 TX Edition Silverado
    - McGaughy's 4/5 Drop Kit
    - Apline Type R 10s & Amp
    - Airaid CAI
    From what I understand, the floor on the crew cab is different so it allows for a bigger box. The floor in the extended cabs are oddly shaped. I will be buying my subs when I sell my current 12's and box and also when I get my tax refund
    Oh.. yeah i just checked out the difference in the two.. nearly an inch mounting depth. that sucks man.
    I've heard that some people raise their seats mounting point up an inch or so to allow for more room. But then, grown ups will find it hard to sit back there lol
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Quote Originally Posted by 2k8z71 View Post
    Technically, I guess you not are completely removing all of it, but you are replacing the blocks and the u-bolts, so it's close. I just balanced everything carefully on the floor jack and did not have any problems.
    TIRES:
    BFG All Terrain KO 315/70/17
    So u don't really have to unbolt them at the ends. Just the u bolts and the center bolt that holds them together?
  8. #18
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Nope....just take the pressure off the spring buy using the jack under the differential, switch out the block and u-bolts, and use 2 c-clamps near the center of the springs to hold them in place, which includes your add-a-spring which goes right above the bottom (helper) spring.
  9. #19
  10. #20
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    It is.....I wish the rest of the kit went on that easy
  1. CUSTOM 2X 10" SUB ENCLOSURE??05 rado crew cab
    By phattmatt in forum Audio, Video & Gadget Tech
    Last: 01-16-2010, 10:04 AM
  2. Switch Enclosure
    By Oscarvan in forum General Chevy & GM Tech Questions
    Last: 09-19-2009, 07:59 AM
  3. 02 Crew Cab Sub Enclosure
    By thejms in forum Audio, Video & Gadget Tech
    Last: 04-23-2009, 02:32 PM
  4. 2001 Silverado Ext Cab Sub Enclosure Dims
    By MB3 in forum Audio, Video & Gadget Tech
    Last: 04-15-2009, 09:54 PM
  5. 2000 gmc sierra extended cab subwoofer enclosure help?
    By ajfootball61 in forum Audio, Video & Gadget Tech
    Last: 01-18-2009, 08:07 PM
