    Default Transfer case front seal
    The front drive shaft seal on my 2000 1500 4x4 is leaking pretty bad. Anyone have any expierence replacing the seal. Can it be done in the truck?
    Thanks
    Sr. Engineer
    Dec 2011
    11-22-boogie woogie avenue
    Usually if seal leaks there is a problem ..do you have any play in shaft? Can be done in truck ..but you have to have a special tool to pull seal.
    If no tool have to split case to drive seal out. Have to get tool from gm.
    Didn't check to see if it had any play when I was under it, will do next time. Sounds like it isn't a simple hammer in place seal.
  1. Transfer case, front drive shaft, or what? Any ideas?
    By wbmartin3 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-16-2012, 11:49 PM
  2. 99 Tahoe transfer case rear seal leak
    By aabuck5 in forum GM Powertrain
    Last: 03-15-2010, 02:58 PM
  3. Front & Rear Diff and Transfer Case Fluid Change
    By al96chev in forum General Chevy & GM Tech Questions
    Last: 11-24-2009, 11:12 PM
  4. front & rear diff. & transfer case fluids
    By redneckarmyMP in forum General Chevy & GM Tech Questions
    Last: 10-09-2009, 11:00 AM
  5. WTB 241c Transfer Case & Front Drive Shaft
    By homer911 in forum General Classifieds
    Last: 02-16-2009, 10:25 PM
