    Default How to test distributor and fuel pump
    is there a way to test if my distributor is good or bad? and how do i go about testing my fuel pump?
    Thank you
    Year/engine would help us give you more specific answers.
    Unless this is real old school (pre '88 or so), the way you test the fuel pump (and the rest of the fuel system) on a fuel injected vehicle (whether TBI or CSFI or other fuel injection system) is to put a fuel pressure gauge on it and see if the pump is generating sufficient pressure.
    Testing the distributor is usually about testing the consistency and quality of the spark. Does it fire consistently? Is the spark a nice blue color? If you pull the distributor off, are there any cracks or other indications that the spark is going elsewhere? Contacts corroded or worn?
    sorry its a 95 suburban k1500 5.7
  1. How To: Test TBI Distributor Signal/Injector Pulse
    By dualdj1 in forum How-to Guides
    Last Post: 03-19-2012, 11:36 AM
  2. HELP!!!!Changed fuel pump and ECM. fuel pump still wont turn on
    By fast_stang_88 in forum GM Powertrain
    Last Post: 06-03-2011, 04:46 AM
  3. How do I Test the Coil on the top of the distributor?
    By Holy Smoke in forum General Chevy & GM Tech Questions
    Last Post: 02-06-2008, 01:02 AM
  4. Fuel Pump test wire/oil sending unit/ignition mod
    By odb138 in forum Performance & Fuel
    Last Post: 01-29-2008, 12:16 PM
  5. Fuel Pump Test Wire / Oil Sending Unit/ Ignition Module
    By odb138 in forum General Chevy & GM Tech Questions
    Last Post: 01-28-2008, 03:56 PM
