Results 1 to 10 of 11
    Default 6" Fabtech lift kit on a 02 2500 8.1 liter Vortec.
    I'm currently trying to decide on lifting my Silverado. I want to lift it 6" with like 37" or 38" tires on it, but I want to know how much this will reduce my towing capacity. If there is anyone who has lifted this size engine be for I would love some advice and help.
    02 Silverado 2500hd|496ci bigblock|Botch fuel pump replacement|True dual Magnaflows|UV-10 Jensen head unit|All four speaker Kickers|Kicker tweeters|10in Kicker sub|250watt Kicker Amp|Volant Cold Airintake|PowerAid Throttle Body Spacer|33in Nitto Trail Grapplers|8000k Hid Halo Lights
    Jr. Engineer
    SWAT13's Avatar
    Feb 2012
    Live in Mississippi...But I claim Texas!!
    37's will be just fine..but ur gonna need a hella drop hitch!!!! lol
    2011 Silverado "Black Widow Edition"
    7" Lift
    35" Mickey Thompson Baja ATZ's
    20" American Racing Rims With -24 offset
    Recon Smoked Led Tail and 3rd Brake Lights
    MCX Conversion Package.....
    Custom Dual Exhaust
    Custom Leather
    Custom Chrome Gauges With Red Back-Lighting
    Black Widow Badges
    Back-up Camera System
    Programmer
    Full Length Nerf bars
    Bull Bar
    Fender Flares
    Hood Scoop
    Pioneer Head Unit
    Custom Sub Box With Two Competition 10" JBL's
    Rockford Fosgate 1000w Prime Amp
    if you go that big with the tires you will want to regear or you will lose some of your low end power for towing. On the hitch yes you will need a bigger drop hitch. I found one for my truck that drops 7.5" and you can adjust it with the trailer attached for leveling. I also have one that drops 11.5 inches that i use for a small trailer I tow . I got the 11.5" drop one from harbor freight for like 25 dollars but like I said that one just tows a small 1500lb trailer. The other one I use for the heavier trailers.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Ya on the topic of re-gearing, I was just kicking around the idea of a super charger on the 8.1 liter. Only problem is my model Allison only handles like 350 or 450 horse powers. Where the super charger ads 150hp. Just a wild idea I've seen people do it in YouTube its some crazy power.
    I don't remember if the 2500's are IFS or not. I will assume they are. I think that a 38" tire is too much for that suspension. I understand it is a 2500 but the added weight of the tires seems too much to me. Not sure how they beefed it up for the added capacity so I may be way off base with what I just said. If that is the case I am sorry for wasting your time.
    The 2500 has ifs but it is stronger than the 1500. Bigger ball joints etc. I know the recommendation on the 1500 is no bigger than 35s. I would think 37s should be fine on the 2500. As with anytime you go bigger juzt gotta check everything a little more often. Even moreso if he is gonna do more offroading etc.
    To the OP. Especially if you go real big tires with the supercharger i think gears would be important. With all the extra power and then weight of the tires. Breaking things would be a good possibility. Transmission rearend etc.
    David
    NRA Life Member
    Well I'm not to educated on the Allison trany but I know mine only can withstand 450hp and if I super charge it I know I'm going to have to replace it. What I want to do it replace it with a Allison that can take 550hp safely and I'd also put a chip in it to help with the shifts (not sure which one to go with yet) but I think i might just superchage it cause all that power and a lift kit wouldn't set to good.
    When are you planning to get the lift done? I'm really curious to see how it turns out with the 37s. I've been considering doing a 4" if I could fit 35s. I should be able to do it, but everything I've read says 6" for 35s. However, I know the tires I have on the stock truck right now are about a 32.5" diameter.
    To Be Completed (Eventually):
    2002 2500 should be able to fit 35" tires with a 4" lift, 37" with 6". Try a BDS suspension lift, they offer 6.5" or 7".
    www.youtube.com/ippielb
    Master Mechanic
    Dirty Dog's Avatar
    Mar 2012
    Regina Saskatchewan Canada
    Quote Originally Posted by Jason2325 View Post
    I have seen and will be getting a torque converter for the dirty dog, that will allow you 150 +horse power... you will need to retune and retrain the trans after installed.... I have been told that this is best done by the Allison service department... but I personally have messed with the retraining of the Trans, on dirty dog with a Edge Evolution CTS and have had no issues....here is the link for you on the torque converter..http://www.transmissioncenter.net/allison1000.htm and i have found others out there as well.....
  1. Buying New 2012 Truck F250 6.2 Liter Gas vs. Sierra 2500HD 6 Liter Vortec
    By Todd00601 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-08-2012, 10:49 PM
  2. 8.1 liter Vortec lift.
    By Jason2325 in forum Chevy Truck Talk & News
    Last Post: 02-24-2012, 12:35 PM
  3. Adding coil spacers to a 6" fabtech lift?
    By WheatSnackBread in forum Lifted & Offroad Suspension
    Last Post: 01-10-2012, 08:35 PM
  4. 07 08 09 10 chevy silverado 4wd 6" fabtech lift kit
    Last Post: 12-11-2011, 01:59 PM
  5. 3" lift kits by Fabtech for sale!! (89-97) gmc & ch
    By Arthurwelding in forum General Classifieds
    Last Post: 01-03-2010, 09:06 AM
