    Default ECM removal in 1995 C1500
    I have a 1995 C1500 with the 4.3l engine. I ordered a stage 1 chip for it and I will need to remove the ECM to install it. Are those hard to do? I belive its behind the glove box. Any tips or advice will help. Thanks all!
    Jan 2012
    Sault Ste. Marie, Ontario Canada
    You got it... behind the glove box. Its straight forward. Disconnect POS terminal on battery. Remove OEM chip, install new chip, reconnect battery. GO!
    My lug nuts require more torque than your Honda makes.
    Actually, you should remove the NEGATIVE battery cable first. For that matter, you don't have to remove any cable to replace the ECM as long as the ignition is "OFF" while you do it.
    Good Luck and God Bless
    Sr. Engineer
    Dec 2011
    11-22-boogie woogie avenue
    Chip will probably give you trouble......all i have to say about that.
  1. Ball joint replacement on 1995 C1500 2wd
    By Crispyt in forum General Chevy & GM Tech Questions
    Last: 06-01-2012, 06:47 AM
  2. 1995 c1500 5.7 Water Pump
    By seph in forum General Chevy & GM Tech Questions
    Last: 12-26-2011, 01:31 PM
  3. 1995 C1500 Randomly turns off
    By Anv1319 in forum General Chevy & GM Tech Questions
    Last: 04-11-2010, 07:38 PM
  4. 1995 c1500 wt
    By 95WT in forum Chevy C/K Truck Forum
    Last: 07-27-2009, 03:03 PM
  5. 1995 Silverado C1500 reg. cab longbed FS $2400
    By zieg72 in forum General Classifieds
    Last: 04-05-2009, 10:07 PM
