    Default Removing door panel on 12 silverado
    Removed 3 bolts and seems something is still holding it. Are there more that I'm missing? Seems real tight up by the top right.
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    If I remember correctly (it's been awhile since I've had them off), there should be two under the vertical handle (one on top, one on bottom), one under the horizontal handle (arm rest) and one under the handle that actually opens the door....at least that's how they were on my 2008, which should be the same as your 2012.
    Which three have you removed already?
    Also, when you mention "top right", are you referring to the driver's side door or the passenger door?
    TIRES:
    BFG All Terrain KO 315/70/17
    Quote Originally Posted by mfleetwood View Post
    Which three have you removed already?I had 2 behind horizontal handle. 1 under door handle. Thats where it seems to be tight is at vertical handle. How do you access the bolts there?
    Drivers side actualy have found 4 forgot about 1 when i poped out window control there was one there. Seems tight at top of vertical handle. Got one behind handle and 2 behind horizontal handle.Seems like theres one at top of vertical handle.
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Yes..there is one at the top of the vertical handle on mine. Once I removed that curved flat piece that covers that area, it was easy to see. Have you taken off that piece?
    Thats what I needed to know thanks! Looks like the other one I took out didn't need to. How does the cable release?
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    I can't remember a cable on mine. If you are referring to the wiring, there should be a connector behind the plastic that leads to both the mirror and windows/locks. If it's a cable, hopefully someone else can answer that one for you soon.
    Alot of it will depend on which style door panel came with your pickup too
    Friends dont let friends drive fords!
    Proud GM Technician
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Ok...I actually had to take my door panel off again yesterday and now remember that there are two bolts below the armrest...and the cable goes to the door handle/lever used to open the door; however, I did not need to fully remove the door panel. I took a look at it and it looked to be too much work for the time that I had left to finish up.
    Did you ever get it figured out?
    Red Z71 Max's Avatar
    May 2011
    Myrtle Beach, SC
    There are 2 bolts under the verticle handle, 2 bolts behind the horizontal handle and 1 bolt behide the unlocking handle. There is also a cable attached to the unlocking handle that is a BIG pain in the butt to get off.
    (Scott) Myrtle Beach, SC
    January 2012 ROTM WINNER
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Quote Originally Posted by Red Z71 Max View Post
    It definitely looked like it, thus I decided to leave it alone until something forces me to take it off.
  1. How to Remove Door Panel on an '05 Silverado
    By MWright936 in forum How-to Guides
    Last: 10-30-2011, 10:31 PM
  2. Rocker Panel Removing Suggestions Help?
    Last: 06-13-2011, 11:22 PM
  3. 07 Silverado door panel lights flashing
    By Scott51 in forum GM Electrical Tech
    Last: 12-13-2010, 03:21 AM
  4. hey all how does the door panel come off in a 2000 silverado 1500
    By Bbad in forum Audio, Video & Gadget Tech
    Last: 12-28-2008, 04:09 AM
  5. Removing driver door panel on 1999 tahoe
    By rgulbrandsen in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 06-02-2007, 10:04 PM
