Thread: ABS light
    Default ABS light
    I did u joints on my 2003 yukon xl a week ago. Drove it about 300 miles with no issue. I noticed a vibration today around 30 mph. So I jack the truck up, put it in gear and got it up to about 30mph. I did not see anything weird with the drive shaft, and the joints are not warm after a hard 60 mile drive. So, I get back into the truck, put my foot on the brake until the tires stop and put it in park. All of a sudden I noticed the Brake light and the abs light came on. I shut it down and restarted it. The brake light went off but the abs light is still on. any ideas?
    Could be that while the back end was jacked up the low fluid sensor inside the master cylinder reservoir went off, as your fluids would have been pushed towards the front. If it's not completely full then I could see this happening. other than that....?? I am kind of at a loss. Nothing about what you've done sticks out to me as anything that would cause a brake malfunction.
    "Truck Norris"
    - 2008 TX Edition Silverado
    - McGaughy's 4/5 Drop Kit
    - Apline Type R 10s & Amp
    - Airaid CAI
    Never mind. I drove it around the block and it went off.
    good deal. probably all it was bud.
    Apr 2011
    Thornton, Colorado, United States
    My guess is that the truck recognized the speed differential between the front and rear wheels and turned on the warning light.
    Alan
    2010 GMC Sierra SLT
    2007 Chevy Suburban LTZ 4WD, aka BB
    murdog94's Avatar
    I second the differential this time, though the vibration could be any number of things, from tires to a bad wheel bearing. to rear diff etc.. Hopefully it was just a fluke with the vibration.
    Mike
    Currently
    2011 F-150 Crew 4X4
    Quote Originally Posted by Alan Crosby View Post
    I hadn't thought about that.. good lookin' out!
    I think that must be what it was! The vibration was because The new u-joint was bad. Slaping between the straps in the rear.
  1. Tail Light/ Head Light Smoked Tint Finally pulled the trigger for $40!
    Last: 09-24-2011, 01:47 PM
  2. 99 Tahoe weird tail light/brake light/hazard light/blinker problem NEED HELP
    By beckya99 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 07-11-2011, 10:46 AM
  3. Dome light and cargo light not working
    By Randy0702 in forum Chevy Truck Tech Forum
    Last: 01-26-2011, 08:36 PM
  4. 99 Chevy Silverado Map Light Dome Light OEM USED
    Last: 11-30-2009, 07:40 PM
  5. Batery warning light and odometer light on - help
    By filmir in forum General Chevy & GM Tech Questions
    Last: 09-29-2009, 11:54 AM
