    Default 09 silverado wheels
    Hey guys, I have a 2009 Silverado LT with 17in rims. I found a set of 18in z71 rims that i would like to put on it. can anyone tell me if these will clear? thank you!
    Quote Originally Posted by BILLP View Post
    Clear what? Do you have bigger brakes, bigger tires, lift, drop?
    Welcome to the Club!
    2010 OEM 20" Wheels
    Color-matched mirror covers and emblem
    20% tinted windows - 6" eyebrow
    Black rear fender-wells
    Completely debadged and demolded
    Duramax airbox replacement w/ K&N filter
    2" Rear drop shackle
    Tailgate light bar
    Flowmaster Delta 50 w/ double tip exits
    Blue footwell lighting
    12" Pioneer Sub (custom downfire box) 850W amp
    Full LED interior
    Thanks for the welcome and answering so quick Cheez. my truck is still all stock, I put oem wheels with snow tires on this winter and every once and awhile when turning & hitting bumps or dips, the tire hits up front.
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    As long as you keep the same diameter and width tire as stock (i.e. 31" x 11"), regardless if it's a 17" or 18" rim, you'll be fine. Another good reason to keep the same diameter for your purposes, if you don't have a programmer, is so that your computer reads the correct speed regardless which set of wheels/tires you have mounted.
    BTW...Welcome to the Club!!!
    ---------- Post added at 05:25 PM ---------- Previous post was at 04:59 PM ----------
    Here is a link that will let you play around with tire sizes if you're looking to keep the same diameter and width that would fit the 18"s.
    http://www.1010tires.com/TireSizeCal...?action=submit
    TIRES:
    BFG All Terrain KO 315/70/17
    @mfleetwood pretty much nailed it. I went from stock 16" wheels to stock 20" wheels on my truck. The only problem I've had is the speedometer/odometer being off.
    Quote Originally Posted by Cheez View Post
    They should fit fine. But as mentioned above, your speedometer will be off a little.
    Quote Originally Posted by TELORVEHC View Post
    I know they'll fit. They've been on for nearly a year. I was giving my situation to help @BILLP feel better about going up 1" in size.
    Last: 01-21-2012, 07:21 AM
  2. Replies: 0
    Last: 01-12-2012, 01:30 PM
    Last: 12-25-2011, 10:20 AM
  4. Replies: 0
    Last: 12-16-2011, 09:40 PM
  5. PLEASE HELP 06 Silverado wheels
    By nickt6494 in forum Lifted & Offroad Suspension
    Last: 11-27-2008, 11:37 AM
