Results 1 to 2 of 2
    Default Bad Fuel Pump on the 8.1 Vortec?
    I was doing a compression check on my truck the other day. When I took out the spark plugs they looked like crap and only burning on one side. I had just replaced the plugs not even 6 months ago. So I continued with the compression check and then got online to see what the compression read on a 8.1 liter should be I had know luck with finding it but I did read somthing about these trucks having bad fuel pumps. Does anyone know anything about this and if I do need to replace it do I need to order a new one or aftermarket one? Also I never found what the PSI should be in 8.1 all my reads where above 175 and I think that sounds right. Any help would be nice.Click image for larger version.
Name:	2012-03-15 15.44.09.jpg
ID:	36266Click image for larger version.
Name:	2012-03-15 15.43.46.jpg
ID:	36264Click image for larger version.
Name:	2012-03-15 15.43.56.jpg
    02 Silverado 2500hd|496ci bigblock|Botch fuel pump replacement|True dual Magnaflows|UV-10 Jensen head unit|All four speaker Kickers|Kicker tweeters|10in Kicker sub|250watt Kicker Amp|Volant Cold Airintake|PowerAid Throttle Body Spacer|33in Nitto Trail Grapplers|8000k Hid Halo Lights
    Quote Originally Posted by anneparker View Post
    I want to increase speed of my chevy car which I bought from a sale. I think it need full refurnishing and speedometer which is making obstacles for high speed. do you think i can get those.
    What make, model, year? We need more info.
  1. HELP!!!!Changed fuel pump and ECM. fuel pump still wont turn on
    By fast_stang_88 in forum GM Powertrain
    Last Post: 06-03-2011, 04:46 AM
  2. Nylon Fuel Lines/Fuel pump recommendation
    By jed1124 in forum Chevy Truck Accessories
    Last Post: 03-21-2011, 08:10 PM
  3. Replies: 4
    Last Post: 09-19-2010, 06:16 PM
    Last Post: 09-26-2008, 05:10 PM
    Last Post: 09-05-2008, 02:55 PM
