Results 11 to 19 of 19
    Jr. Apprentice revscott's Avatar
    Mar 2012
    Montgomery AL
    Quote Originally Posted by Z71_guy View Post
    The lean is probaly caused by the torsion bar on the drivers side being worn out. Known as the Chevy lean you can just crank the t-bar key up to level it out
    thanks, but I'm not familiar with the t-bar key. Where is it, what do I do?
    The Rev
    Quote Originally Posted by revscott View Post
    I seem to have a little slack in my steering. It is most noticeable at hwy speeds. Dangerous im sure and a little scary. What could be the cause and is it something I may be able to fix myself. Im not ASE certified but Im pretty good with cars. RWD at least!
    I have been burdened with a dreaded steering slop for a while, I have replaced tie rods inner and outer, pitman arm, idler arm, and just replaced the steering box in November, along with dual steering stabilizers, and the new steering box did wonders for two months, until the box **** the bed and now it's twice as worse as it was before. So now i have another replacment box to put on that hopefully will work instead of this garbage.
    First thing i would do is look for the problem, then go from there, more likely it will be the tie rods.
    www.youtube.com/ippielb
    Sr. Engineer Dana W's Avatar
    Dec 2011
    Chuluota, Florida
    The "T" bar key is a lever sort of at the back end of the torsion bar. You can't miss them. The torsion bars are 3 or 5 feet long and run from your control arm backward parallel to the frame rails. There is an adjusting bolt running through the "T" bar key that is captured in a plate on the frame. Turning this bolt will lift or lower your front suspension on one side or the other by rotating its associated torsion bar.
    CAUTION - turning this bolt also changes your spring rate by adding or removing preloaded tension into your torsion bar. If one of the bars is sagging low and the adjusting bolts are more or less already equally adjusted the same amount then your torsion bar is probably weakened somehow. The "T" bar keys however, are not meant to be adjusted to raise or lower the vehicle. They are used to remove tension from the torsion bar so it or your control arm can be removed for repair and used to level the truck up after the torsion bar has been installed. They are like having "on board" spring compressors.
    This brings me to a question. Exactly how much does the prior owner of your truck weigh anyhow.
    I bought my '99 Burb from a guy who tops 300 lbs and it still sits level after 13 years. The driver's seat however, has a distinct list to Port.
    ---------- Post added at 10:52 PM ---------- Previous post was at 10:33 PM ----------
    Quote Originally Posted by ippielb View Post
    along with dual steering stabilizers.
    Two of 'em? I've heard those things, along with hugeomongous meats eat street spec GM (and most other brands) power steering boxes like Wheaties. You prolly should carry a spare one.
    Mar 2012
    Montgomery AL
    Thanks but I am not familiar with the t-bar key. Can you tell me where it is and what to do.
    Sorry for double post, thought I had lost it. thanks for replies.
    [QUOTE=Dana W;452894]
    The "T" bar keys however, are not meant to be adjusted to raise or lower the vehicle. They are used to remove tension from the torsion bar so it or your control arm can be removed for repair and used to level the truck up after the torsion bar has been installed.[/QUOTE]
    The other use is for adjusting ride height for doing alignments. So in away they are meant to raise or lower your truck just not to the max.
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Dec 2011
    Chuluota, Florida
    [QUOTE=Z71_guy;453073]
    Quote Originally Posted by Dana W View Post
    Of course. I just figured I didn't need to add "to look like Billy Bob's mudbogger." at the end.
    Master Mechanic
    Dirty Dog's Avatar
    Mar 2012
    Regina Saskatchewan Canada
    Hey ,,,Uncle BillY Bobs Mudbogger is a sweet ride .......
  8. #18
    Dec 2011
    Chuluota, Florida
    Quote Originally Posted by Dirty Dog View Post
    Billy Bob is a girl.
  9. #19
    Master Mechanic
    Dirty Dog's Avatar
    Mar 2012
    Lmao OOOPs
  1. Slack in transmission
    By Philip Greer in forum GM Powertrain
    Last: 09-25-2011, 11:51 AM
  2. Too much slack in gear selector. Any solutions?
    By rojoho79 in forum General Chevy & GM Tech Questions
    Last: 08-16-2010, 12:40 PM
  3. Drivers electric seat has slack
    By new2dis in forum Chevy Silverado Forum (GMC Sierra)
    Last: 08-08-2009, 11:52 AM
  4. slack in the steering wheel?
    By tpirob in forum Lifted & Offroad Suspension
    Last: 08-23-2008, 02:07 AM
  5. DJTricky im new cus me some slack lol
    By DJTricky in forum Member Introductions
    Last: 04-19-2008, 10:35 AM
