    Default Rear Brake Troubles
    I was driving home from work this morning when I noticed a burning smell. When I got home I noticed smoke coming from the passenger side brake drum. I noticed the parking brake cable that ran to that brake drum was under tension even tho the parking brake was released. I unhooked the cable thiking that this would be a temporary fix until I can get the brakes apart this weekend, but even with the cable unhooked that brake is still getting quite hot. Any suggestions or things to look for would be greatly appreciated. Its a 2005 4WD, just FYI
    Sr. Engineer Dana W's Avatar
    Dec 2011
    Chuluota, Florida
    You probably have a stuck "E" brake actuator lever(s) inside the drum. You are going to have to be prepared to replace or at least clean up some parts once you get inside the drum. Getting in is not going to be easy since the shoes are probably pressed up against the inside of the drum. Try this to free them. Stick a small screwdriver in the adjuster access hole in the backing plate and push the e brake actuator off of the star wheel. That might free up the shoes so you can get the drum off, which you will have to do once the actuator is off the star wheel.
    You can tell if the shoes are free if you can rotate the drum an inch or two taking up the play in the diff. If you can't move it or it is tight, you can maybe back off the adjuster star wheel enough to get them free. I can't for the life of me remember which way to turn the star wheel though. I always get it wrong the first try anyway,
    x2^^^^^^^^^^
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  1. What size brake front-to-rear-brake line?
    By NorthJersey in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 08-25-2012, 01:43 PM
  2. rear brake question
    By bart6180 in forum Chevy C/K Truck Forum
    Last: 07-11-2011, 11:07 AM
  3. rear end troubles
    By 57chevykid in forum GM Powertrain
    Last: 06-13-2010, 02:40 PM
  4. Wierd rear brake valve linked to rear axle housing..what is it?
    Last: 01-31-2008, 01:56 AM
  5. the rear deflector thats on top rear above 3rd brake lights [Expired Topic]
    By 97bigredburban in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 09-13-2005, 12:34 PM
