Page 1 of 11 123 ... LastLast
Results 1 to 10 of 102
    Default New Transmission Cooler....
    A few years back I installed, a Mag-Hytec Aluminum Finned Deep Transmission Pan, after noticing that my Transmission Temps were running around....180-190 and sometimes just over 200 Degrees, after installing it, I saw a Drop in my Transmission Temp's to around 180/190 Degrees.....But I still was Not Comfortable having my Transmission running at these number's.......even tho these number's are with-in the Temp's expressed in the Owner's Manual.........As I and Most of you guys Know the Biggest Killer of Auto Transmission's is.....HEAT!!!.
    After doing some research regarding Swapping out my Factory Trans. Cooler with a Larger Aftermarket Transmission Cooler......The Aftermarket Transmission Cooler of choice I was seeing, is the True Cool 40K Transmission Cooler.
    So after ordering not only the 40K Cooler, I ordered a EAD's Transmission Mounting Bracket Kit, which comes with New Upper and Lower Mounting Brackets for the 40k Cooler.....along with all the Mounting Bolts-n-Hardware and 2 Inverted Flair Fittings and the Compression Fitting.
    Below are some pictures of the install of the True Cool 40K Transmission Cooler
    Factory Transmission Cooler
    New True Cool 40K Installed With New EAD Upper and Lower Mounting Brackets
    Install of the Inverted Flair Fittings to both of the Transmission Hard-lines
    Install of the Compression(Brass)Fitting........to be able to Spin the Passenger Side Hard-Line 180 Degrees to Line-Up/Fit onto the Threads of the 40K Cooler
    Below are the Items/Parts that come with the 40K Cooler
    The 2 Inverted Flair Fittings and Compression(Brass)Fitting that were supplied in the EAD Mounting Bracket Kit,
    Mag-Hytec Transmission Pan
    http://www.mag-hytec.com/transmission.htm
    ........This past Saturday we when Boating and this was the first time Towing my Boat with the New 40K Transmission Cooler.....the Temp's were in the low to mid 90's.......the Transmission Temp's Never went over 150 Degrees!!.......about 30/40 Degrees Cooler than with the Factory Transmission Cooler......I would just say that this is without question the Best Mod I've done to help with Cooling my Transmission Temps.......
    Anyone Towing a Boat or Travel/Car Trailer....this would be a item to keep in mind for a Up-Grade......The Time it took to do the installed.......was a little over Hour......for the most part this was Plug and Play Installed, the only Mod was the cutting of the Passenger-Side Hard-lines for the Compression Fitting.....
  2. Thanks Steve thanked for this post
    Likes Steve liked this post
  3. #2
    Wow thats quite an improvement over the factory trans cooler
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  4. #3
    Quote Originally Posted by dsfloyd View Post
    Ya David, I was Very Pleased when seeing the Trans. Temp I mentioned, this new cooler is almost....3 Times Larger than the Factory Cooler.....after hearing/reading about other guys who have done this Cooler Swap, I felt it was worth a try.....I'm glad I did this Upgrade!!
  5. #4
    did you notice any difference with engine temps (going up) due to the larger area covering the radiator? Probably wouldnt due to the fans doing a good job of pulling air through the radiator but thought I'd ask.
    David
    NRA Life Member
  6. #5
    That was one item that I thought about David, But my Engine Temps were the same as they were before installing this larger Cooler....
  7. #6
    murdog94's Avatar
    That looks like stock and works better my fav type of mod.. guess i need to take a look at one for the ram since we all know how much those trannys like heat even though i have the new 5spd auto! thanks for showing how easy is actually is!
    Mike
    Currently
    2011 F-150 Crew 4X4
  8. #7
    Nice mod and informative write up Mike, sounds worth doing even though I don't tow much.
    Adam
  9. #8
    Well, that's very interesting to say the least. It makes sense that a larger trans cooler would do a much more effective job for cooling, I didn't think it would do that much of a difference. 90 degrees is like nice bath water, lol.
    Steve
    10 Chevy Traverse LT AWD
  10. #9
    Nice write-up Mike!
    :cool:
    Weather Tech floor mats
    Cover-Craft seat covers
    Dash mat cover
    Formula One window tint
    One black Lab in rear seat.
    :glasses:
  11. #10
    stephan's Avatar
    Far West, Oregon USA,
    Those are good numbers Mike. Your weather is about the same as here during boating season. How much does your boat & trailer weigh?
    3" susp. lift kit "shadetree"
  1. Transmission Cooler? Need to drain out a quart of Transmission Fluid
    By Fitzi722 in forum General Chevy & GM Tech Questions
    Last Post: 06-30-2011, 10:38 PM
  2. Transmission Cooler
    By Tiny1987 in forum Chevy Truck Accessories
    Last Post: 04-05-2011, 04:47 PM
  3. transmission oil cooler
    By DutchTBI in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 03-03-2007, 09:48 AM
  4. Transmission cooler
    By coachw-n-themrs in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 07-06-2006, 11:37 PM
