    Default Transmission Replacement
    What year model Chevy interchanges with my 93 1500 4L60E Transmission? I'm understanding no later than 94 due to electronics
    Sr. Engineer Dana W's Avatar
    Dec 2011
    Chuluota, Florida
    Quote Originally Posted by rrrandy View Post
    My 1999 K1500 Burb has a 4L60E trans.
    Master Mechanic SupplySgt's Avatar
    Feb 2010
    Middle TN, displaced Okie
    IIRC the 4L60E remained unchanged from 93-96. However, there were several changes made in 97 I believe and I don't think those are able to communicate with the 96 and older PCMs. I'm not 100% certain on that but 93-96 you should be alright.
    93 Suburban (Southern Slayer): TBI 350, 4L60E
    73 Z28 Camaro: L82, TKO 600
    KJ4CLI
    "...Death smiles at us all, all a man can do is smile back..."
    This will probably only muddy the water rather than add clarity, but here's what I know and don't know about interchangeability of OBS 4L60E's
    '92 or '93, not sure which, 4L60E is introduced. Before this, it was either the 700R4 or 4L60 without all the electronic controls.
    '93 to '94 seem to interchange just fine.
    '95 is it's own year. Can't remember all the whys, but it seems like it is mostly in the solenoids/valve body. But, I also don't hear of anyone just interchanging valve bodies, so I think there is more to it than just the valve body.
    '96 to '98 seem to interchange just fine.
    With the switch for OBS to NBS that started in '99 and finished in '00 or '01, the 4L60E was different between OBS and NBS versions. So, when you want to fit a '99+ 4L60E into an OBS truck, you need to make sure it came out of an OBS ('98 and earlier) body style.
    So, it seems to me that you first indication ('93 or '94 to go into your '93) was probably the right indication.
    Feb 2010
    93 was the year that the 4L60E was introduced in the trucks. Passenger cars didn't get it till 94. That much I am certain of.
    KJ4CLI
    Over read a yahoo.answer by tranny tech that a TCC (torque converter control )sylinoid was added to our lovely 4L in 95 making the old ecm garbage and more electro B S added later......................someone please verify..................Oh! obs vs nbs?
    Dec 2011
    Chuluota, Florida
    That actually clears it up quite well.
    The first "E" 4L60 was introduced in 1993, this early model was changed in 1995 to include a PWM pump. The solenoid configuration was changed in 1996, and this currently is the way the electronics are configured. The Late 4L60-E was released in 1997 and fully phased into wide use through GM by 1998 in both RWD car platforms and trucks in both 2WD and 4WD configurations The key distinction of the Later 4L60-E (1997-2006) from the Early 4L60-E (1993-1997) or 4L60 (1990-1992) or 700R4 (1982-1989) is the six-bolt "hex" rear output or tailhousing / adapter pattern. The previous versions featured a four-bolt square bolt pattern at the adapter or tailhousing. The removeable bellhousing is also another distinguishing feature from 1997 to present. The bellhousing changed with the new 5.3 engine. The differences are which holes the bellhouse uses to bolt the transmission to the block. The newer 5.3 bellhousing is also deeper and takes the b-85 converter rather than the b -29 torque converter.
  1. Finding the right transmission for replacement
    By jvz71 in forum GM Powertrain
    Last Post: 10-20-2009, 01:37 PM
  2. aftermarket or stock transmission replacement
    By Wiyr in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-23-2009, 04:54 AM
  3. Transmission Replacement HELP NEEDED PLEASE! !
    By laramik in forum GM Powertrain
    Last Post: 05-22-2009, 09:06 PM
  4. Transmission Replacement HELP NEEDED PLEASE! !
    By laramik in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-22-2009, 12:34 PM
  5. Replies: 0
    Last Post: 06-08-2007, 11:53 AM
