Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. #21
    Sep 2011
    Fairbanks, Alaska
    6.5 kappas are a different design then the 4x6s. You can put the crossovers where ever you please.
  2. #22
    he did say they were the 2-way 6.5" infinity kappas, so here is a picture of the 2-way infinity kappas...
    unless he has something other than what he described im afraid he will have to mount this (external crossover) inside the door as well
    i really think we just need the originator of this thread to be the one to tell us what his speakers look like, or we might all continue to see different pictures lol
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
  3. #23
    Sep 2011
    Fairbanks, Alaska
    Lol yea for sure because those aren't what I saw either haha
  4. #24
    Nov 2010
    Cedar Rapids Iowa
    This is the exact model i got Infinity KAPPA 652.9I 6.5" 6.75" 225W 2 Way Car Audio Speakers 6-1/2
    They come with cross overs in the 6.5 model but not the 6.75, i guess, might be wrong. What is the purpose of a cross over any way?
    2003 K1500HD-Straight Pipe, Drop -In K&N Filter, 3" Lift Soon, H2 Rims
    1993 C1500 ECSB- Open Headers, Performance Shift Kit
  5. #25
    Sep 2011
    Fairbanks, Alaska
    Ok. Saw the pic and it matches what reggie is talking about. As lame as it is, you have no choice but to mount the hard wired crossovers in the door. You could cut the speaker wire and mount them in the cab and run a length of wire into the door and solder to where you cut but that will cause a longer install time.
    Crossovers are designed to allow the woofer and tweeter to share a common input power but allows them to separately replicate sounds on different frequency levels. Tweeters are your highs while the 6.5" woofer is your mid. A crossover is basically a frequency filter. The reason yours is designed the way it is is because your tweeter is sitting inside the cone of your woofer. On most component sets the woofer and tweeter are separate and the crossover is also separate. Yours looks to be a "high bred" sort of setup designed for an easy install for the user. The sound should be similar if not only slightly less accurate then that of a true component set.
  6. #26
    ziggers got you now!
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
  7. #27
    Nov 2010
    Cedar Rapids Iowa
    Good info. Now i got the speakers and i went to put them in yesterday morning and i have no idea what goes where. i had everything unplugged and apart but i dont know where im supposed to wire the factory wires to? or do they go in the crossover? ive looked around online and nobody seems to of posted much about these speakers.
  8. #28
    Sep 2011
    Fairbanks, Alaska
    There should be an input on your crossover. Your factory positive/negative wires go right into the input. Then slap your new speakers in. Hope this info wasn't too late. Sorry I've been super busy!!
  1. Infinity Kappa Perfect 6.1
    By GrizzlyTN in forum Audio, Video & Gadget Tech
    Last Post: 10-18-2010, 10:43 PM
  2. Need advice/ help on install
    By MXZ1983 in forum Audio, Video & Gadget Tech
    Last Post: 02-01-2009, 10:51 PM
  3. infinity basslink II
    By bzboardco in forum Audio, Video & Gadget Tech
    Last Post: 01-22-2009, 11:54 AM
  4. Stereo Install...Need Some Advice
    By toolskizm in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-17-2009, 07:45 PM
  5. Infinity Basslink??
    By hutch_pt in forum Audio, Video & Gadget Tech
    Last Post: 06-08-2008, 08:00 PM
