Results 11 to 20 of 20
    my 2000 p/u steering moaned when during cold weather and so do I
    2012 4.8 LS
    Check the dust seals around the shaft. I had a truck come into the shop with the same problem and it ended up just being the column shaft rubbing on some rubber.
    Please Tell Your Boobs To Quit Staring At My Eyes
    Quote Originally Posted by osgprometheus View Post
    Anything in particular to look for?
    The truck that came in had tilt steering. Where the tilt dust cover went under the top side of the column into the dash was rubbing on the shaft.
    I've got tilt, as well. I'll check this.
    Let me know. I'll hop back on to see what you came up with.
    Did this fix the issue? Could you post some pictures of the area you are supposed to inspect please? Thank you!
  8. #18
    I've got steering wheel moan in my 2004 GMC Sierra. It happens only when turning the wheel to the left and/or returning it back to center after a left turn.
    PS fluid levels have been checked and are fine. I did the steering clunk fix (zerg fitting and grease) some time ago and am sure it's not the intermediate shaft 'clunking' as it's prone to do. I talked to a mechanic who basically said, 'don't worry about it', however it grates on my nerves and I want to identify and fix the problem.
    The sound seems to come from column, itself. Any thoughts as to where/what I should be looking at for this?
    I had the same issue on my 05. I tore apart the column and found nothing. I had a warranty on it and found a small leak in the steering gearbox. I had them replace the gearbox and to my surprise the moan stopped immediately. It really sounds like it is in the column, but the sound travels up the steering shaft.
  9. #19
    My son has this same issue.... we replaced pump still problem still exists. My mechanic friend says there is a valve on the pump or something that controls the fluid flow. Since we reused everything but the pump my guess is our problem is the valve. This maybe what everyone else is experiencing.
  10. #20
    Quote Originally Posted by TimTom64b View Post
    I replaced my pump also, no change. it was a valve inside the gearbox.
  1. Steering wheel swap, 2006 silverado to 2008 steering wheel?
    By Dontlookforme in forum Chevy Truck Accessories
    Last Post: 11-17-2010, 01:37 PM
  2. Knocking in steering wheel when turning
    By rrod7390 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-08-2010, 02:50 AM
  3. Power Steering Whine only when turning LEFT, CONFUSED!!!!
    By Burnall4 in forum General Chevy & GM Tech Questions
    Last Post: 08-08-2009, 11:19 AM
  4. squeaking noise when turning steering wheel to the left
    By satrdanitefvr in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 06-05-2009, 11:00 PM
  5. Noise in steering column when turning
    By sasksuburban in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-20-2008, 09:10 PM
