    Question Truck Norris (08 1/2 ton 5.3 w/4l60 &g80) Vibration in 2nd gear.
    Alright, as the title says I've got a strange vibration when under a load (aka normal driving... aka 3/4 throttle or more lol) but ONLY when reaching the 4000 rpm mark and then it continues until the shift into 3rd and disappears.
    This started happening as soon as I dropped the truck basically and obviously it is bothering the heck out of me..
    I am kind of stumped as to what could be causing it, because (correct me if I'm wrong) a u-joint, off-balance driveshaft, or anything of that sort should be consistent throughout the entire gear span shouldn't it?
    Just curious if anyone has had this same issue or not before? I couldn't find anything already in the forum.
    "Truck Norris"
    - 2008 TX Edition Silverado
    - McGaughy's 4/5 Drop Kit
    - Apline Type R 10s & Amp
    - Airaid CAI
    Does that truck have a mid-shaft bearing? I have seen those things cause all sorts of crazy vibration issues. I had a cracked u joint strap in the rear but it only vibrated between 35 and 38 mph, When it got worse it vibrated all the time.
    Makes sense.. i haven't yet gotten underneath him to check and see if anything was loose, as i am only actually in possession of him 5-10 days a month lol. but that's something ill have to check! thanks bud
  1. Update on Truck Norris ~ Chevy Silverado
    By 08_rado_rocker in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-10-2012, 08:10 PM
  2. bad vibration only when floored in first gear
    By rich89 in forum GM Powertrain
    Last: 05-23-2011, 07:13 PM
  3. 92 S10 vibration in gear?
    By hutch_pt in forum Chevy S10 Forum (GMC Sonoma)
    Last: 03-01-2009, 07:51 PM
  4. Chuck Norris - What you never knew about the man.
    Last: 01-06-2007, 10:33 PM
  5. Chuck Norris - 100 things you never knew about him!
    Last: 02-08-2006, 02:28 PM
