    Default 3/4 ton torsion key on a 1500
    Greetings All,
    I saw a truck yesterday that had some 285 tires on it. It looked like a lot of rubber! The front clearance looked close but it had plenty of room in the rear. I asked the guy if he had any lift work done. He said all he had done was install some Torsion Keys from a 2500 truck. Is that something that is being done?
    1989 Chevy V1500 Suburban 4X4, long tube headers & xover pipe. w/1985 350 4bbl.
    2002 Silverado 1500 5.3L Ext. Cab
    2005 Wrangler Rubicon 4.0L
    1990 Miata
    Sr. Engineer
    Dec 2011
    11-22-boogie woogie avenue
    285,s will fit without raising the torsion bars any . If you go any bigger can use bars to lift up to 2" any over this
    Will mess with alignment.
    Is that forest hills N C? if so i used to live there when i was a kid.
    No, I'm in Maryland. Apparently there is a Forest Hill in many states, cause I hear that alot........
    Apr 2009
    You can use 3/4 ton keys but as mentioned, you will need an alignment afterwards. Not sure how they compare to adding height to just a regular leveling kit to your truck. I know for a fact that the 03-06 trucks can run 33's without a leveling kit since I ran with that setup for a year with minimal rubbing daily driving, but just comparing my dads 2000 to mine, his seems to ride a little lower and would be skeptical if he could run bigger than 265's without some rubage on stock.
    Also remember that when you go up a tire size, you will need to recalibrate your speedo.
    2005 Chevy Silverado W/T
    Planned mods not in order
    I have a 2002 silverado, and had 285/75r16 with stock height. Didn't crank the torsion bars at all. Upgraded to 33x12.50r18 and i had rubbing issues. AS for the torsion keys, the 2500 will fit the 1500, but if you want to cheap out, buy torsion keys off of a stock early 2000's F150 from a junk yard, they fit and have an offset to raise the truck around 3".
    www.youtube.com/ippielb
    Sr. Apprentice TnT817's Avatar
    Nov 2011
    Dayton, Ohio
    Won't cranking up the torsion bars wear out the front end a lot faster because of the cv and ball joint angles?
    Apr 2009
    Quote Originally Posted by TnT817 View Post
    Yes. And because you can't have less than 10 letters in a post, I will say "Yes" again....along with all the rest of that.
  1. Chevy 1500 3" TORSION BAR KEY LEVELING LIFT KIT 4WD
    By parts bot in forum Chevy Accessories eBay
    Last: 02-20-2012, 10:10 PM
  2. 07 1500 torsion bars??
    By IAsilverado in forum Lifted & Offroad Suspension
    Last: 10-15-2010, 02:57 PM
  3. Are 1500&2500 torsion keys the same?
    By WEEBOB in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 04-03-2010, 08:22 PM
  4. 1500 torsion keys level out 2500's??
    By 04chevy2500hd in forum Lifted & Offroad Suspension
    Last: 03-01-2010, 02:54 AM
  5. 04 'Burb 1500 4X4 - Adj. Torsion Bars?
    By BCD in forum Lifted & Offroad Suspension
    Last: 09-19-2008, 08:17 PM
