Page 2 of 4 FirstFirst 1234 Last Post byLast Post by
Results 11 to 20 of 34
    Okay just another thing I'd like to throw out there for everyone to consider. This truck sees a decent amount of highway and it seems to me that with a cold air intake and a spacer at highway speeds you'd have to see an increase somewhere. I'm not by any means looking for a huge amount of power out of this or a huge amount in mileage increase.
    2000 Chevy Silverado 4WD Classic
    2'' lift Torsion Keys and air shocks
    33/12.50 Hankook Dynapro M/T
    3 1/2'' down pipe back 6" Tip
    Dodge Towing Mirrors
    Smoked Tails, Cab Lights, and Side Marker Lights
    1% Rear and Side Window, 20% Front Tint
    American Racing Wheels/ With a custom black paint
    Cold Air Intake
    Edge Performance Chip
    Custom Audio System
    LED Tails
    Black background headlights and parking lights
    Added one as part of a total Engine Performance upgrade, so no specific changes or performance gains to directly link to the TB spacer.
    If you are going through the process of making upgrades as are listed below, then adding a couple bucks ain't no big deal.
    That's just my 2 cents worth...
    Pavement sucks... :grrrrrr:
    1994 K1500 4x4 Ext. Cab
    PCM chip and Xenon 8000k bulbs
    350cu.in bored over .050"
    balanced Crank, 10:1 compression
    Flat top pistons,cam,ported heads
    Option Racing Cold Air Intake
    Holley Throttle Body Spacer
    Accell Igition, 45kv coil
    FloTech Headers, no CATs, dual exhuast
    Goodyear Silent Armor A/T 305/70-16
    Pioneer SupertunerIII CD USB Bluetooth
    Kicker ZX200.2 ZX Amp
    Kicker Audio COMP 10" Subwoofer
    Is there any difference between all the different brands of the spacers? Or are they pretty much all the same?
    Quote Originally Posted by MTM View Post
    Chair... Moon. It's as simple as that. Does it matter whether the chair is leather or wood. The end result will be the same. There are no magical bolt on products that are going to make any real difference in and of themselves. Your engine is nothing more in the end than a big air pump. You get more air in and more air out to make any additional power, period. Adding a spacer not only has no way of getting any more air into the system, but the laws of physics actually dictate that such a device would add length to the path of the air and therefore cause friction loss due to the additional surface area of the spacer... ESPECIALLY if it is one of those ones with threads cut into it to "twist the air". Hand one of those to a smoker and have him blow smoke through it. You will then see that the air is not spinning out the other side.
    But what about a cold air intake? You can bore a manhole sized hole in your intake and force gobs of air into the system, but if the air doesn't have the means to escape (out the exhaust) then your new and improved hole won't help you either. Think about a 5 inch fire hose hooked to a hydrant with 150 psi of force going in from the hydrant. Let's also suppose that you are running a length of 100 feet of 5 inch hose. With the other end of the hose open, you will only get about 135 psi at the other end because of the friction loss in the hose. Now, let's adapt it down and hook a garden hose to it. You will still get 135 psi, but you will have no volume. Instead of flowing 5 gallons per second, you are maxed out at 1 gallon per minute. Make sense?
    Your engine will only pull in as much air as it can get rid of.
    Thanks for that write up that pretty much says it all. think ill look into some other things to mess with.
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Since you're looking around for something else to mess with and Tom did such a great job with the fire hose analogy, I'm thinking an exhaust will go nicely with your CAI........maybe?
    TIRES:
    BFG All Terrain KO 315/70/17
    There is no maybe about it ... if he chooses wisely. And yes, @moogvo did one heck of a job with a stellar analogy; props to you, sir.
  8. #18
    Wow! Thank you! I expected to get flamed over that. There are guys that swear by those things and they will fight you over it, but you can't argue with simple physics! LOL!
  9. #19
    My background is in engineering, so you got no argument from me.
  10. #20
    I'm actually a college student in engineering so no it all makes since there's no argument here. And i do have an exhaust it's a 3 1/2'' down pipe back into a 5'' tip
  1. Throttle Body Spacers
    By Bowtie Man in forum POLLing place
    Last: 11-03-2011, 12:09 PM
  2. Throttle body spacers
    By SoonerSilverado11 in forum Performance & Fuel
    Last: 01-21-2011, 10:21 AM
  3. MAF / Throttle Body Spacers
    By Zo1shot in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-07-2010, 10:52 AM
  4. throttle body spacers
    By blakk0nine in forum Performance & Fuel
    Last: 11-23-2009, 03:49 PM
  5. throttle body spacers
    By ss_silverado_phoneix99325 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-10-2007, 10:14 PM
