GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Thanks for the compliments! More stuff. Front winch is the original, holds 300 ft of 1/2 inch cable and was rated at 10,000 lbs. It's huge and is now hydraulic drive. I mounted a winch drive motor to the trans cross member. The dual lever valve and filter is under the seat. Rear winch is a 13,000 lb Tulsa and is a 1/3 the weight of the front winch. Dual levaers in the cab control the winches amd the PTO knob can bee seen on the dash to engage the hydro pump mounted to the Allison PTO. No ladders bars, torque rod as used on army trucks. Winch roller fairleads were hand made. I built steps into the cable guides. The column is a Flaming River Shorty tilt. Steering wheel I desigClick image for larger version.
Name:	Big Rip the 42 G.I. Chevy 207.jpg
ID:	37238ned and had built same as the wheels.
ID:	37233Click image for larger version.
ID:	37234Click image for larger version.
ID:	37235Click image for larger version.
ID:	37236Click image for larger version.
  2. #12
    Default "Stars and Stripes" the 42 G.I. Chevy.
    Thanks guys. I love this site! More stuff. Front winch is original 10,000 lb rated Garwood rated and is huge, holds 300 ft of 1/2 inch cable. Garwood also made WW2 PT Boats. Rear is a 13,000 lb Tulsa. The dual lever hydro valve is under the seat. I mounted a winch drive motor to the trans cross member for the front winch. The hand made cable roller guides have steps built in. Torque rod as used on G.I. trucks uses factory parts accept the cross member mount. The WW2 Chevy used the same sheet metal and running gear as the CCKW, the WW2 GMC "Jimmy" duece and a half so the parts could be canabalized from one shot to hell to the other. Also as phot of the exact same truck restored, a 42 G7117. The only thing missing are the wooden bows and canves bed cover. Had fold down troop seats.They came in bomb loading models, open cab for loading and removing bombs from planes, fire trucks, wreckers, dumps, even a Van model used by the Signal Corps stuffed with radio gear.Original engine was an 235 ci, 83 hp overhead valve 6 with 4 speed crash box, 6:73 gears, 2 speed T Case. It was geared so lo that you could pull up to a wall in lo/lo on pavement, drop the clutch in 4 wheel drive and the tires would go chug, chug with the engine idling..
ID:	37239Click image for larger version.
ID:	37240Click image for larger version.
ID:	37241Click image for larger version.
ID:	37242Click image for larger version.
ID:	37243Click image for larger version.
ID:	37244Click image for larger version.
ID:	37245Click image for larger version.
  3. #13
    looks good man!
    i dig the truck alot. someday i might have to get something similar.
    Alex
    2011 GMC Sierra SLE 5.3 Z71 4X4 Stealth Gray Metallic / 2004 Chevy Impala LS 3.8 Cappuccino
    Tow mirrors - Diablew Tuned - Flowmaster Regular 40 - Ready Lift 2.5' lift - BFG LT A/T K/Os - Carr Light Wing - TruckLite LED lights - Optima Red Top - 50% Front Window Tint - Line-X bedliner - Airaid MIT - Tekonsha P2 - ARS Billet Grill - Fia custom fit seat covers
  4. #14
  5. #15
    Master Mechanic
    Dirty Dog's Avatar
    Mar 2012
    Regina Saskatchewan Canada
    Keep the pics coming,,, your thread here is one of my daily stops,, and luv'en it......
  6. #16
    Here is a video of a 350 small block I built from scratch using a cedar wood block to keep the weight down;
  7. #17
    Legend
    mfleetwood's Avatar
    Jul 2010
    Denver, CO
    Very creative! I've never seen an engine used in that manner
    Mike (Denver, CO) - 2008 Sierra 1500 Z71 SLE 5.3L 4WD
    SUSPENSION: Rancho 4" Suspension Lift; Rancho RS9000XL Shocks; Rancho Skid Plates; Rancho MyRide Wireless Shock Controller;
    TIRES:
    BFG All Terrain KO 315/70/17
    DRIVE TRAIN: 4.56 Gears; Detroit TrueTrac Differential; True Cool 40k Transmission Cooler
    PERFORMANCE: DiableSport Predator Tuner; Custom Tuned by Diablew; Magnaflow Exhaust; AFE Cold Air Intake
    ELECTRONICS: Kenwood DNX6180 Touchscreen; Subthump box w/10" Kicker; Driver Information Center (DIC); Rear View Camera
    ACCESSORIES: Westin Brush/Grill Gaurd; Westin Nerf Bars; Truxedo Tonneau; 20% Tint; Tow Mirrors w/Heat & Signals
Similar Threads
  1. Chevrolet : C-10 62 CHEVY PU "LOADED" " NO RESERVE " Finance/Ship
    By parts bot in forum Chevy Trucks For Sale eBay
    Last: 12-15-2011, 01:10 PM
  2. 1961 Chevy "TRUCK" 348 - #'s MATCHING "REMANUFACTURED" ENGINE
    Last: 12-02-2011, 07:20 AM
  3. GM wants to Dump "CHEVY" nickname, keep "CHEVROLET"
    By ChevyFan in forum The Coffee Shop ~ Chit Chat
    Last: 09-01-2010, 11:35 PM
  4. Replies: 0
    Last: 07-24-2007, 12:30 PM
