    Default 2001 Chevy Tahoe, motor swaped, how to tell what exactly which motor I have?
    Is there a simple way to tell what model motor you have in a car? My 01 Chevy got a motor put in and after a couple of days looking at it, it looks like a slightly smaller engine than what I remember having.....
    Sr. Apprentice CowsPatoot's Avatar
    Nov 2010
    Wilkesboro, NC
    Unless they swapped a V6 in place of the V8, then you won't be able to tell by physical size...all the V8s are the same dimensions on the exterior. It is the bore and stroke of the cylinders that make it a "bigger" or "smaller" V8. You can verify it is still a V8 by counting the spark plugs.
    Everyone should own a Ford once in their life....how else can you truly appreciate a Chevy?
    Quote Originally Posted by CowsPatoot View Post
    I do realize this but I'm looking for the actual year and model of the V8 motor....
    I'm just trying to understand better.. but what exactly makes you think that the motor in your vehicle now is "smaller"?
    ---------- Post added at 12:47 AM ---------- Previous post was at 12:30 AM ----------
    But to answer your question a lil better... the casting stamps are usually located on the passenger side of the block near the top of the bell housing casting if I'm not mistaken, but I'll research some more and see what i can come up with.
    ---------- Post added at 12:55 AM ---------- Previous post was at 12:47 AM ----------
    http://outintheshop.com/faq/casting/castings2.html
    This should help if you can find the casting number on the block. And i think i was wrong before.. it may actually be on the DRIVERS side of the block.
    "Truck Norris"
    - 2008 TX Edition Silverado
    - McGaughy's 4/5 Drop Kit
    - Apline Type R 10s & Amp
    - Airaid CAI
    Quote Originally Posted by 08_rado_rocker View Post
    Hey thanks, I just looked in those areas without success. Should I be looking from underneath or ok from above? Also would it be above or below the cam covers? Below the exhausts? P.S I also have some paperwork from the salvage yard, which they confirmed today is from 02' Silverado. I had an 01' Tahoe, and I know those are pretty much the same... I'm just trying to satisfy my own itch of knowing from what's on the motor/engine for myself vs. what the receipt says...friends of mine have had issues with the installer...trying to see I got what receipt says I paid for.... thanks very much...
    I don't think you can tell between a 4.8 and a 5.3 from the exterior. You have to get into the internals.
    "If it ain't one thing, it's a mother******g nother"
  1. 1999 2000 2001 Silverado Transfer Case Encoder Motor
    Last Post: 01-30-2010, 07:50 PM
  2. 2001 suburban 4 by 4 5.3 motor
    By japsmash2001 in forum General Chevy & GM Tech Questions
    Last Post: 12-30-2009, 07:08 AM
  3. 2001 2500hd. Anyone ever replace motor mounts?
    By thrasher in forum GM Powertrain
    Last Post: 01-14-2009, 09:04 PM
  4. 2001 to 2007 blower motor resistor
    By tallt1924 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-06-2008, 08:07 PM
  5. 2001 sierra window motor
    By angsur in forum General Chevy & GM Tech Questions
    Last Post: 05-30-2008, 11:35 AM
