Results 1 to 10 of 15
    Default Differential fill and drain plug
    2001 Burb with 150k miles. Is there a drain and fill plug on the rear diff? I can barely see a plug in the bottom with a 1/2" or 3/8" square drive but I cannot seem to find the fill plug looking from the rear tires. I am hoping not to remove the diff cover. Thanks.
    If I remember correctly on my '99 burb, it is on the front half of the pumpkin, on the passenger side. You wouldn't see it from the back.
    I like you.
    You could always vacuum it out...
    Quote Originally Posted by janikphoto View Post
    Thanks.
    I will take a look again tonight.
    There is a fill/check fluid level plug. To empty you need to either vacuum out like said above or take the cover off. I recommend just to take the cover off and take some brake clean and spray all in there and clean out any gunk. Doesn't take to long and its definitely worth it!
    2006 Duramax LBZ
    Edge Evo
    4'' Diamond eye to 6'' tip
    Lots of work left to do!
    Quote Originally Posted by ntbush83 View Post
    Good advise.
    Do I need some sort of cover gasket or RTV will work? Thanks.
    I would suggest just going and buying the gasket then putting on some RTV for safe assurance. Sometimes your gasket will be reusable but thats a pretty rare case and no need to take chances for a few extra bucks!
    Went to the dealer and got the gasket. PN 15807693 @$10.23. Will tackle this project tomorrow. Thanks again.
    The plug you see on the bottom (if it is on the very bottom of the pumpkin) is the drain plug and is a 3/8" ratchet head. There should then be another one (3/8" again) for the fill and level on the passenger side of the pumpkin as stated by janikphoto about midway between the back of the diff and driveshaft. as stated by ntbush83 and since you have the gasket go ahead and open it up and clean it out then close it back up and refill. Before draining very important that you make sure you can open the fill plug on the side, other wise you will have an empty diff without a way to fill it back up.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    Quote Originally Posted by dsfloyd View Post
    yes, will make sure the fill plug can be cracked loose first before I drain. good advise.
  1. Suburban Transmission "Drain and Fill"
    By LowcountrySuburban in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-11-2014, 06:18 PM
  2. Radiator drain plug
    Last: 05-05-2011, 03:20 PM
  3. Transmission Pan Drain Plug Kit
    By BustedKnuckles in forum GM Powertrain
    Last: 01-26-2011, 02:38 PM
  4. HELP! rear diff fill plug welded shut!
    By Ronnell21 in forum General Chevy & GM Tech Questions
    Last: 02-08-2010, 05:38 PM
  5. How do you drain rear differential lube 98 Suburban?
    Last: 12-16-2008, 07:31 PM
