Results 1 to 10 of 11
Thread: Grease Fittings
    Default Grease Fittings
    On a 2011 Silverado 4X4 1500 How many Grease Fittings.
    Thanks
    Dave
    I found them guys, only 2 fittings on tie rod ends at the wheels, also I noticed no drain plug on the rear like my 02 Silverado had. Just a fill plug. The Trans pan looks easy to remove when the time comes. All in all maintenance looks a little better then my 2002 Silverado 4X4
    Dave
    2011 Silverado Ext. 4X4
    Leer hard body tonneau cover
    Z71 Appearance Pkg. 18" Wheels
    Rancho shocks
    There's a bunch, top ball joint, lower ball joint, outer tie rod, inner tie rod, pitman arm, idler arm, kingpin, u joints, if you're intermittent steering shaft has one. and then any other extra's you've installed.
    www.youtube.com/ippielb
    No grease fitting on is shaft, need a new one, clunks are annoying lol
    2003 GMC Sierra 1500 SLE 5.3
    Factory Tint
    Recon Taillights
    2.5 ReadyLift Leveling Kit
    Low Profile Toolbox
    Westin Nerf Steps
    ippielb, On my 2002 Silverado Ext 4X4 I greased something like 10 or 11 fittings every year for 9 years and the front suspension on my new 2011 silverado
    is not the same, GM made a major change at some point. I will get a Haynes or factory manual.
    Dave
    So there's only 2 grease fitting on our whole truck it's time for mine to get a few pumps. I've been thinking bout doing that steering shaft grease fitting trick
    2009 chevy 1500 z71 4x4
    Default Only 2 Grease fittings
    Quote Originally Posted by ahmitchell1 View Post
    Thanks, I know I find it's hard to believe, but it is only 2. One on each tie rod end.
    Dave
    It's well worth it. I shared that trick with a friend of mine who is a mechanic while discussing steering wheel moan with him ... and he thought it was brilliantly simple/easy/effective.
    Yea I'm not really having an issue with my steering but I feel like it may prevent anything and maybe improve my steering
    Former Member
    Apr 2012
    Reading, PA
    I found nine fittings on my 2012 2500HD (4wd)...upper/lower ball joints, tie rod ends, pitman arm, idler, and its idler arm. There are no fittings on either of the drive shafts.
  1. 1998 Suburban-C1500- How many grease fittings does it have-found 8.
    Last: 01-01-2012, 01:51 PM
  2. How many Grease Fittings?
    By 178kchevy in forum Lifted & Offroad Suspension
    Last: 03-24-2011, 08:03 PM
  3. Grease points??
    By pino55 in forum Chevy C/K Truck Forum
    Last: 10-10-2010, 10:48 AM
  4. grease fittings
    By nickgiacalone in forum General Chevy & GM Tech Questions
    Last: 04-15-2009, 11:30 PM
  5. Need grease?
    By 1st Synthetics in forum 1st Synthetics
    Last: 03-22-2009, 07:24 PM
