Results 1 to 10 of 38
    Default Oil Consumption Issue
    Hey all, I don't know why I haven't posted about this sooner, but I guess I've just been too into researching my mods. So a couple of months before I left in February, I noticed my truck was starting to get low on oil rather quickly. I didn't find a leak anywhere, but my pressure kept getting really low and I'd have to add it in. Shortly after I left to come over here, in Feb, the check engine light came on and my wife took the truck in to the dealership. They said it looked like the oil hadn't been changed in forever, but when checking their records saw that I'd had them change the oil in January, so the immediately ruled out negligence. (This is the sole reason I get maintenance at the dealership while it's still under warranty rather than doing it myself.) So they said they had to do oil consumption tests and told her to bring it back every 1000 miles. Well, she took it back in late march but they couldn't find the paperwork so they said they had to start it over. They did check the level though and it was down 2.5 quarts from where it was in Feb so they added some oil and told her to come back in 1000 miles again. The fact the paperwork was not found is frustrating but is also the first time I've had an issue with that service department, so I won't be too harsh on that. Anyway, they're going through all the tests so that if something needs to be replaced they can ensure it's covered by the warranty, so that's good at least.
    However, I've gotten no information regarding what might actually be going on. Nor have I gotten any information on what damage might be going on with this and which parts might need to be replaced. Needless to say I'm a bit concerned. My father-in-law, who's always skeptical of anyone, said they're just hoping to extend the life until the warranty runs out so they don't have to replace the engine. I'm not so concerned with that since there's about 2+ years and 50,000 miles left on the warranty.
    Does anyone have any idea what might be going on? I'm at a loss and just hoping whatever it is isn't going to have long term negative effects and gets fixed appropriately.
    As always, thanks for your input.
    To Be Completed (Eventually):
    Does your engine smoke from the exhaust and have a funky smell to it?? (dont go huffing huge plumes of exhaust gases obviously lmfao)
    "Truck Norris"
    - 2008 TX Edition Silverado
    - McGaughy's 4/5 Drop Kit
    - Apline Type R 10s & Amp
    - Airaid CAI
    No. I've noticed no odd smells and no smoke. Granted, I haven't driven it in two months, but like I said it started before that, and basically, it'd be just fine and then suddenly I'd put some gas into it and the check engine light would come on and the DIC would say something to the effect of "Oil pressure low ZOMGWTF Turn engine off now!!" I believe that's a direct quote from the DIC.
    Anyway, I found the following TSB. I apologize for the length:
    #10-06-01-008B: Engine Oil Consumption on Aluminum Block Engines with Active Fuel Management (AFM) (Install AFM Oil Deflector and Clean Carbon from Cylinder) - (Mar 7, 2011)
    Subject: Engine Oil Consumption on Aluminum Block Engines with Active Fuel Management (AFM) (Install AFM Oil Deflector and Clean Carbon from Cylinder)
    Models: 2007-2009 Cadillac Escalade, Escalade ESV, Escalade EXT
    2007-2009 Chevrolet Avalanche, Silverado 1500, Suburban, Tahoe
    2007-2009 GMC Sierra 1500, Sierra Denali, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL
    2008-2009 Pontiac G8 GT
    Equipped with Aluminum Block V8 Engine with Active Fuel Management (AFM) (RPOs LC9, LH6, L76, LFA, L92)
    with Greater than 45,000 km (28,000 mi)
    This bulletin is being revised to add the 2009 model year and new Correction information for the 2009 model year - left rocker arm cover replacement. Information has also been added after step 9. Please discard Corporate Bulletin Number 10-06-01-008A (Section 06 - Engine/Propulsion System).
    Condition
    Some customers may comment about engine oil consumption of vehicles with higher mileage (approximately 48,000 to 64,000 km (30,000 to 40,000 mi). Verify that the induction system is assembled correctly and that there is no evidence that the engine has been ingesting dirty air due to a mis-assembled induction system. Also verify that the PCV system is functioning properly. If diagnostic procedures indicate that oil consumption is piston/piston ring related, verify that oil consumption is less than 3,000 km (2,000 mi) per liter/quart. If these conditions are met and oil consumption is less than 3,000 km (2,000 mi) per liter/quart, perform the service indicated in this bulletin.
    Cause
    This condition may be caused by oil spray that is discharged from the AFM pressure relief valve within the crankcase. Under most driving conditions and drive cycles, the discharged oil does not cause a problem. Under certain drive cycles (extended high engine speed operation), in combination with parts at the high end of their tolerance specification, the oil spray quantity may be more than usual, resulting in excessive deposit formation in the piston ring grooves, causing increased oil consumption.
    Correction
    2009 Vehicles Only
    Important: This left rocker arm cover is NOT to be used on 2007-2008 vehicles because of the calibration of the PCV orifice being different in 2007-2008.
    A new left rocker arm cover has been released for 2009 engines. Technicians should replace the left rocker arm cover with GM P/N 12642655. This rocker arm cover has relocated PCV drain holes that prevents PCV pullover into the intake manifold. Refer to SI for Valve Rocker Arm Cover Replacement - Left Side.
    2008-2007 Vehicles Only
    To correct this condition, perform the piston cleaning procedure as described in this document, and install a shield over the AFM pressure relief valve per the procedure outlined in this document. Monitor oil consumption after this repair to ensure oil consumption has improved to acceptable levels. If this repair does not correct the condition, it may be necessary to replace the piston assemblies (piston and rings) with new parts.
    Important: It is critical in this cleaning process that the engine/fuel injector cleaner remain in the cylinders for a minimum of 2.5 hours to fully clean the components. The cleaner solution must be removed before a maximum of three hours.
    •Verify the oil consumption concern following Corporate Bulletin Number 01-06-01-011F. If oil consumption is found, continue on with this bulletin.
    •Remove the spark plugs and ensure that none of the pistons are at top dead center (TDC).
    •Clean the pistons by putting 118-147 ml (4-5 oz) of Upper Engine and Fuel Injector Cleaner, GM P/N 88861802 (in Canada, use 88861804), in each cylinder. Allow the material to soak for at least 2.5-3.0 hours, but no more than three hours and then remove the cleaner. A suggested method of removing the cleaner is cranking engine over. Make sure to unplug the ignition coils and fuel injector before cranking the engine over. Also make sure that the painted surfaces are covered so no damage is done.
    •Remove the oil pan. Refer to Oil Pan Replacement in SI.
    •Remove the AFM valve (1).
    •Install the new shield (1), GM P/N 12639759, and tighten the AFM valve to the oil pan to 28 Nm (20 lb ft).
    Important: Ensure that the engine cleaner is thoroughly removed before reinstalling the spark plugs. Failure to do so may result in a hydro-lock condition.
    •Reinstall the spark plugs. Replace the spark plugs if necessary due to full of carbon. Refer to the parts catalog.
    •Reinstall the oil pan. Refer to the Oil Pan Installation procedure in SI. Replace the oil pan gasket if necessary. Refer to the parts catalog. Replace the engine oil if necessary.
    •Re-evaluate the oil consumption. Document on the repair order. If the oil consumption is still greater than 0.946 L (1 qt) in 3,200 km (2000 mi), replacement of the pistons and rings will be required.
    Important: Some minor scratches may be noticed on the cylinder walls during piston and ring replacement. If the scratch cannot be felt when running your finger nail over it, the scratch is considered normal wear and the block or engine should not be replaced.
    Parts Information
    Part Number
    Description
    Qty
    12639759
    DEFLECTOR-OIL PRESS RLF VLV (quantity of 3 per order) (07-08 Models Only)
    1
    CLEANER, F/INJR 16 OZ LIQUID POUR (Upper Engine and Fuel Injector Cleaner) (07-08 Models Only)
    3
    12642655
    COVER ASM-VLV RKR ARM (09 Models Only)
    1
    Warranty Information
    For vehicles repaired under warranty, use:
    Labor Operation
    Description
    Labor Time
    J7555*
    3.5 hrs
    Install AFM Oil Deflector and Clean Carbon from Cylinder (4WD)
    4.5 hrs
    Install AFM Oil Deflector and Clean Carbon from Cylinder (G8 Only)
    10.5 hrs
    J7561
    Rocker Arm Cover- Left Bank - Replace- (For 2009 Only)
    0.6 hr
    *This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
    GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
    WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
    Cool you found that.. I was actually going to say that I could ask Billy (buddy, GM tech) to check for TSBs on the issue and see if it was a mass problem. Looks like maybe you found the reasoning.
    Yeah, but now it looks like it could be anything from a replacement part to a new engine. Awesome. That'll be fun. Hey, if they replace the engine, does that reset the odometer? lol
    A friend in Ga had his motor All rebuilt on a 07 5.3 Avalanche.. with 50K on it..There has been a few people talking about this.. Nice TSB..
    Thanks for suggesting I look up the TSB. And there it was. And yeah, as the TSB says, it effects 07, 08 and 09s, though it seems the part numbers are different on the 09s. Honestly, my biggest concern is just having it fixed and happen again 3 years from now when I'm out of warranty. How's your friend's avalanche doing? The interesting thing is that my engine's almost at 50k right now as well.
  1. Oil consumption 07 5.3
    By Farmerdave in forum Chevy Truck Talk & GM News
    Last: 01-03-2012, 04:32 PM
  2. Excessive Oil Consumption
    By dbrannen in forum General Chevy & GM Tech Questions
    Last: 10-24-2010, 07:47 PM
  3. 5.3L, 6.0L, 8.1L oil consumption
    By Marcus in forum General Chevy & GM Tech Questions
    Last: 06-20-2009, 11:22 AM
  4. Common causes of oil consumption
    By 1st Synthetics in forum 1st Synthetics
    Last: 06-10-2009, 08:44 PM
  5. Oil consumption
    By jamesscabetjr in forum Member Introductions
    Last: 01-19-2009, 04:20 PM
