Results 1 to 10 of 12
    Default Lift Advice for a newcomer
    I'm new to the club and I'm looking for some advice. I drive a 2007 New Body Style Chevy Silverado Ext. Cab 4x4 and I'm looking to install a lift kit. I'm struggling to decide between a 4" or a 6" lift. Here are the questions I'm looking to have answered:
    1. What size suspension lift would be ideal, 4" or 6"?
    2. What brand/ maker of suspension lift kits is the best or ideal?
    3. What Mud terrain tires are the best? (Brand and Size)
    4. Other advise an experienced owner can give me?
    Budget $2,500 to $3,000
    Thanks everyone!
    First, is your truck a 07 Classic or New Body Style? Second, What is the intended use of the truck?
    Btw, Welcome to the club.
    Quote Originally Posted by EvanStanley View Post
    We are the Borg. Lower your truck and surrender your keys. We will add your biological and technological distinctiveness to our own. Resistance is futile. Erm, I mean ... welcome to GM Truck Club!
    To answer your questions:
    1. There's no ideal; it's a matter of taste. If you're thinking about going more than 4" then you should probably bite the bullet and go for 6". There is such a thing as too much lift (i.e. extreme angles causing rapid wear), but neither 4" nor 6" fall into this category.
    2. There is no best or ideal. This is, again, a matter of taste (and often, budget). BDS, Fabtech, Skyjacker, Rancho, and Rough Country are all pretty common. Buy the best lift you can afford ... but also do your homework so that you're prepared to shore up or avoid any weaknesses ... as each manufacturer has strengths and weaknesses. BDS is often regarded very highly but people don't tend to like the ride of their leaf spring option, for example. The shocks that come with Fabtech lifts are junk, wear out quickly, and ride poorly, for example. There's a lot of lift information on these forums and you'll be rewarded with good information if you'll take the time to search and read, here.
    3. Again, there is no best MT brand/size. This is purely a matter of taste (and often, budget).
    4. See my last sentence in the #3 response, above.
    Welcome to the GMTC, hope you enjoy it here as I do. I see you got your answer already so welcome aboard.
    welcome to the club!
    In order to answer your questions a bit better the intended use is needed. if you just want a mall cruiser than any lift would be ok. If you intend to use your truck off road than something like a Rancho, Fabtech, or BDS kit will do fine. There are ways to upgrade some of the kits,also depending on intended use.
    Some of the same goes toward your tire selection. A popular tire on this forum is the Nitto brand in various styles. If the road noise doesn't bother you than one of the Super Swamper brands are good off road tires.
    As far as lift heights go some like 4" kits. Some like the 6" ones. With a bit more info from you we can give a more detailed answer.
    Master Mechanic
    Dirty Dog's Avatar
    Mar 2012
    Regina Saskatchewan Canada
    WELCOME to the club and enjoy the site.....
    Welcome to the site. I won't repeat what everyone else already said, but it is true. There is no easy answer. It depends on so many factors. You have to be realistic about what your plans are, your budget, etc.. There are a couple of good posts in the Lifted and Offroad Suspension sub-forum. Read through there as I'm currently doing a lot of research on options from simple, to extreme overkill.
    To Be Completed (Eventually):
    Most lifts for our trucks reguire the use of aftermarket rims. With your budget I think you might wanna start with a level and some nice rims and 33s. Then starting saving up more money and you'll have until those tires wear out to decide what lift you wanna do
    2009 chevy 1500 z71 4x4
    Hello and welcome from San Diego! Agreed with above, but excited to see what you go choose and make sure to keep us updated with pics!
    Click the ^banner^ and save up to 15% on Chevy mods.
    We price match, simply call 888-591-8563 or
    Click-to-Chat and
    we'll beat ANY price by $1.
    *View our 2011 Silverado Build Page here
    Welcome to the G M T C !
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
  1. AZ Newcomer
    By Bourbon5 in forum Member Introductions
    Last Post: 06-19-2010, 05:28 AM
  2. Newcomer
    By dfhollums in forum Member Introductions
    Last Post: 09-29-2009, 01:41 PM
  3. I need lift advice
    By TexAg95 in forum Lifted & Offroad Suspension
    Last Post: 06-26-2009, 04:08 PM
  4. lift kit advice
    By raulibarra3 in forum General Chevy & GM Tech Questions
    Last Post: 10-25-2008, 03:18 PM
  5. Need advice on what lift to get
    By bry2500 in forum Lifted & Offroad Suspension
    Last Post: 10-13-2008, 01:04 PM
