    Default Need help replacing evap core
    i have a huge leak in my 1988 chevy C1500 evaperator core and i have no idea how to replace it please help me guys
    Obviously if you have a leak, the system is/or should be already empty, otherwise you need to have an EPA certified mechanic perform the proper refrigerant reclamation and subsequent recharging when you are finished.
    You will have to remove the blower/duct assy from under the dash in order to replace the evaporator coil.
    Weather you can remove it without taking out the dash panel, I can't say, It may be possible, but may be more work to not have it out of the way.
    2010 Silverado LT 1500 5.3L 4X4
    '95 BMW K1100LT
    '97 BMW K1100LT
    You can get the evaporator out without having to remove the dash. I would suggest you get your hands on a manual to see where all the screws are located. As I recall, it's a real pain in the butt because you have to spend so much time lying in the floor under the dash.
    Good Luck and God Bless
    May 2012
    Buckholts, Texas
    I was just laying in the floorboard of my 98 1500 looking at my evaporator trying to figure out if the guy at the auto store lied about there being a second orifice tube in there, and it looked fairly easy to access. i'm a big guy, and it's kinda cramped, but it looked like if I unhooked it from the accumulator, it'd pull right out. i'd have to go back and look. I hope you already have this figured out, as this post is kinda old. I just joined and thought I'd post something.
  1. replacing evaporator coil and heat core
    By greatdane in forum Chevy C/K Truck Forum
    Last: 04-27-2011, 07:21 PM
  2. 1996 Chevy Suburban rear heater core needs replacing. HOW?
    By bigbird90650 in forum General Chevy & GM Tech Questions
    Last: 09-13-2010, 03:28 AM
  3. Replacing ac evaporator core
    By rondo in forum General Chevy & GM Tech Questions
    Last: 03-23-2010, 10:22 PM
  4. Gas going into evap box
    By solo3500 in forum Performance & Fuel
    Last: 11-10-2009, 01:52 PM
  5. EVAP System?????
    By cchas14 in forum Performance & Fuel
    Last: 07-08-2008, 01:05 PM
