Results 1 to 10 of 13
    Sep 2011
    Rockwell, North Carolina, United States
    Default Does anyone have Air horns/Train Horns on their truck?
    Im looking into putting a single air horn on my 85 Silverado. I know a lot of guys with RAMs have them but you hardly ever see a chevy with one. On side note: Yes I know air horns are technically illegal...
    How I am going to install mine:
    A buddy is giving me a single trumpet style horn. Im going to fab up a air tank out of high pressure PVC pipe and mount it under the truck some where haven't decided exactly where yet. Then ill make it where its easy to fill up and maintain. It will be operated on a 12 volt solenoid on a momentary switch in the cab.
    Royce
    BUILT, NOT BOUGHT
    1985 Chevy Silverado Longbed 4WD
    400 Chevy Small Block/400 Chevy Transmission
    Detroit Lockers Front & Rear/4.10 Gears
    35" BF Goodrich Mud Terrains/6" Rough Country Suspension lift
    I had them on an old blazer I had. Great for scaring people at walmart.
    No PVC pipe. Just get you a 1 gal air tank. Alot safer and is made for your intended use.
    http://www.amazon.com/gp/product/B00...d_i=B000O7WM2I
    Quote Originally Posted by Royce Lancaster View Post
    Royce
    Depends on how loud it is. If it falls within your state's limit, then it should be legal. If it blows leaves off of trees and makes cats screech, then it's probably not within those limits!
    Use a pressure regulator. That's how you adjust the volume on those. If you use an adjustable regulator, you can really rip out the sound and then turn it down when you want.
    Quote Originally Posted by 07XCSB View Post
    X2 I used to have ome onmy cummins ram. Coming from someone in the pipe business do not use PVC. Get that 1 gallon tank and find a cheap compressor off Craigslist or something I'd put it face down underneath your bed it'll scream. I had that first. Then a friend got rid of his so I grabbed his horns and ran a set up front and keep the original set up. It was too loud great for game days tho,ROLL TIDE. Anyway if your lucky you can get the whole set up for 100 bucs. There's a white Chevy classic here with the triple horn set up on his room. Not a fan but it's loud
    2009 chevy 1500 z71 4x4
    Story about train horns on a big truck , was following two other trucks a few years ago on hwy 13 in Tenn. On the CB a driver said his sister usaually sits on the front porch in the mornings . We got close and sure she was sitting on the porch reading a newspaper, he blasted those horns, newpaper went flying and she jumped straight up out her chair. He got a phone call but wouldn't repeat what she said.
    2012 4.8 LS
    Apr 2009
    I love the air horns on my work truck. I blast them at just about everybody I know that I see running down the road, and use them to also scare the deer away from the roadways when I see them. Definitely plan on installing a set on my Chevy in the future.
    2005 Chevy Silverado W/T
    Planned mods not in order
    Sep 2011
    Quote Originally Posted by Jimmeh View Post
    Air Horns are defiantly attention getters.
    Quote Originally Posted by jnbama View Post
    My family owns a beach house in Myrtle Beach about 15-20 mins away from what everyone around there calls the "strip" or "the main drag," on any given night between April and September there are thousands of people out, shopping and checking out the boardwalk attractions. Not to mention all the hot chicks, so I think Ill have some fun with the horn around there.
    Quote Originally Posted by ahmitchell1 View Post
    Thanks for the info, luckily I happen to have one of them laying around.
    The only reason Im considering using PVC is because I have a lot of it laying around the shop, and Im on a tight budget, but I think I have a 2 gallon air tank around the shop somewhere just have to find it.
    Will keep you updated on this upgrade.
    BUILT, NOT BOUGHT
    Sep 2011
    Default update
    I ordered my solenoid for the horn, got my buddy to let me borrow one of his horns and get my system all set up.
    Also I found a old welding tank that will fit under my tool box that I'm planing to use as my air tank.
    Do you guys think i should use a regulator, if so what should it be set at? Its a horn off of a MACK truck..
    BUILT, NOT BOUGHT
    I say use a regulator. What setting, well you will have to play with different setting to get the sound and DB you want. The reg will keep from blowing the horn's diaphram out.
    If you're just planning to fill the tank up from a shop compressor, you could use a regulator to extend your blowing time. Get a real tank (not PVC, small tanks are cheap enough), fill it to recommended max, or max air pressure you can get from your shop compressor, and regulate it down to get longer blasts. Remember though that loudness isn't just about air pressure, it also depends on volume of air to your horns (cfm). With a single horn, you should be alright, but eventually you may want to upgrade to multi-chime horns, and air volume will be more critical. Bigger air lines are always better. I've got two Nathan Airchimes, but only mount one at a time (no room for both). Since I have onboard compressors (capable of 200 psi), I use a pressure switch instead of a regulator. Mine's set at 145 psi, but you can get them at just about any pressure you want. Just think about the future when installing,...what you may eventually want to have in a setup, so that you can avoid having to do it all a second time when you upgrade.
    -Sal
    Desert Brown Metallic
  1. Air horns. Anybody got them?
    By Jimmeh in forum Chevy Truck Accessories
    Last Post: 08-30-2011, 10:12 PM
  2. Train Horns or just louder, manlier horns for my 2010 Sierra.
    By Falcone in forum Chevy Truck Accessories
    Last Post: 11-05-2010, 05:52 PM
  3. Anyone know alot about train horns?
    By Jimbo3 in forum Chevy Truck Accessories
    Last Post: 09-27-2010, 10:54 AM
  4. train horns
    By sharpshooterusmc in forum General Chevy & GM Tech Questions
    Last Post: 05-26-2010, 08:35 AM
  5. train horns
    By Bbad in forum Audio, Video & Gadget Tech
    Last Post: 12-20-2009, 04:20 PM
