Thread: Emblems?
    Default Emblems?
    Whats the best way to peel of the emblems on my truck? Then what should I use to re-apply them?
    A plastic puddy spreader/knife. Less chance of scratching the paint than with a metal one. 3M two side tape to reattach. Stick the 3m on the back of the emblem and trim off the extra with a razor blade.
    Apr 2009
    Quote Originally Posted by 07XCSB View Post
    Make sure you trim off the extra BEFORE applying it to the truck. I know that sounds obvious, but sometimes you gotta state the obvious ;)
    If you don't have a puddy knife, you can use a credit card (don't use one that you still need) and a heat gun. If there is still residue from the old tape or whatever they use, glass cleaner helps take that off or you can spend some money and get an eraser wheel for your grinder/drill if you have one.
    2005 Chevy Silverado W/T
    Planned mods not in order
    Quote Originally Posted by Jimmeh View Post
    Good Point... You can also use rubbing alcohol to romove the residue.
    A spatula with a good edge work also. You can also cut the enblem off with fishing line.
    Thanks you all for the tips, trying them as we speak. Im just painting one emblem black.
    Master Mechanic
    AMac's Avatar
    Feb 2012
    New England
    To remove emblems I recommend a heat gun and using fishing line to work between the emblem and the vehicle. Doing this will likely separate the adhesive from the emblem and then you can remove the adhesive from the vehicle using your thumb to rub it off. Any remaining adhesive can be removed with lacquer thinner or an adhesive remover like TW's sticker and label remover. There are plenty of YouTube videos promoting this method. As suggested above, for reapplying the emblems, 3M has an adhesive that is carried by your local Walmart or auto parts store. I just picked some up the other day in it was about $4.85 for a roll. When removing emblems, be patient and don't try to pull them off because a corner of the emblem can dig into the paint which result in scratches.
    Apr 2009
    I have tried the fishing line technique and while it does work, a plastic putty knife is a lot easier on your hands. I admit I wasn't wearing gloves with the fishing line, but it was not pleasant.....
    I've used dental floss to remove emblems and used rubbing alcohol to remove the rest of the residue and then 3m tape.
    Randy AKA (Sparky)
    06 Z71 5.3L flex fuel
    6" fabTech lift
    LT315/70R17 BF All Terrain
    Pro Comp Series 1059 Wheels
    weather Tech rain shields
    Spectra air filter and air duct tube
    Cheap camo seat covers :lol:
  1. Rbp emblems?
    By chevymanlobo in forum Chevy Truck Accessories
    Last: 08-01-2011, 12:35 AM
  2. Changing Emblems
    By groceryman in forum Chevy Truck Accessories
    Last: 04-07-2011, 07:08 PM
  3. Debadge Emblems
    Last: 03-22-2011, 04:37 PM
  4. Custom Emblems
    By Jimmeh in forum General Chevy & GM Tech Questions
    Last: 12-21-2010, 07:09 PM
  5. zr2 emblems
    By JABLAZ02 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 08-31-2005, 11:07 AM
