    Default coolant leak near rear of the Engine?
    Hey guys, I just bought my S10 a couple weeks ago, everything has been working great. About a week ago I started smelling rediator fluid whenever I got out of the truck, I checked under the radiator and i saw no leaks. Later I checked behind the front tires and near the transmission case there was a small buildup of radiator fluid, the leak is small and I was wondering if anyone knows what it could be from? maybe the heater core hoses?
    Thanks
    Pressurise the coolant system. Check the hoses and intake gasket
    I had a leak similar to this. Mine was on a 350R V8 in a '96 model Silverado. It was a gasket failure at the back of the intake manifold. If yours is a 4.3L it could be the same thing. Good luck!
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    I am going to vote "Intake Gasket". It is common on these engines. DO pressurize the system and look for leaks just the same. Look at the top of the engine along the valve cover and intake to see if you see anything there. Use a mirror to look at the top back corner of the engine to see if it is running down the block.
    What year and what engine do you have?
    The 2.2 has a tendency to blow head gaskets
    I wanna vote water pump gasket/water pump...mine went out on my 03 silverado and i was wondering intake gasket cuz coolant was all over the transmission...i ended of taking the water pump off and the gasket was shot...just throwing that out there...driving down the road the wind will blow the coolant backwards towards the transmission,etc.
    Line-X'd Bed
    5.3L Flex Fuel
    275/65R18 Toyo Open Country AT2's
    2" Rough Country Leveling Kit(want to get the 2.5 RC kit)
    EGR In-Channel Vent Visors
    Exterior PLUS Package
    Interior PLUS Package
    K&N Drop-In Air Filter
    ProFlaps
    Cat-Back Dual Exhaust
    Black Bowties
    ProFlaps
    Towing Mirrors
    Next Planned Mods
    Blacked out Tail Lights
    Aftermarket Rims
  1. 5.3 rear engine oil leak
    By japsmash2001 in forum General Chevy & GM Tech Questions
    Last: 07-04-2011, 07:22 PM
  2. Coolant leak...
    By Jcloud in forum General Chevy & GM Tech Questions
    Last: 07-12-2010, 07:06 PM
  3. Coolant Leak
    By eatfire in forum GM Powertrain
    Last: 07-05-2010, 03:32 PM
  4. Coolant Leak
    By jdsdls in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 09-28-2009, 03:22 PM
  5. Coolant Leak at Rear of Vehicle
    By spark96 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last: 01-17-2007, 12:04 PM
