GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. #11
    Master Mechanic Jimmeh's Avatar
    Apr 2009
    Columbia Falls, Montana, United States
    I agree on not greasing that slip yoke by removing it from the transmission. I am also pretty sure that there is not a grease fitting on the u-joint since I just looked at mine last Thursday and couldn't find one. I also have an aluminum drive shaft, though and not exactly sure if that was stock or not.
    I noticed mine will only clunk if I take it really easy away from stop signs or lights. I still take it easy, but I do goose it a little and it doesn't clunk. Mine will also clunk if I go from having a load on the engine (IE: giving it the beans) to letting off and braking immediately.
    2005 Chevy Silverado W/T
    4X4|4.8 with some mods (has only slightly more pull than a 5.3)|Auto|4 door ex cab|Cooper Discoverer AT/3's in 285-75/17's on Helo 842's|Cooper Discover M+S 265-75/17's on Devino DV349's|Flowmaster 40 Single in Dual out with custom bent pipe from the end of the cats back|2" Procomp leveling kit|Custom made center console|Custom dyno tunes|Air Raid CAI|Air Raid Throttle Body Spacer|Apex brand topper|Kenwood Head Unit with Kenwood speakers|Painted mirrors/grille|Debadged except front emblem|Bilsteins front and rear
    Planned mods not in order
    2 inch lift|Custom front/rear bumper|hitch tire carrier|roof basket on topper, bars on cab|finish center console build|install Midland CB|Power options|Tint|Custom made raised bed in the bed of the truck|Lund LunarVisor
    Also have a 1992 Ford Ranger with a lot of stuff done to it. Currently waiting for a bit of a rebuild.
    "The only woman I'm pimping from now on is Sweet Lady Propane. And I'm tricking her out all over this town."
  2. #12
    This is mostly on the ext cab short bed 4x4's with the aluminum driveshaft. I had the same prob and tried greasing it with all kinds of stuff. Sure it will go away for a month or 2 but it will come back. Brokedown and dished out the 250$ for a nikel yoke. 4 years now no probs. there are no grease fittings on factory equipment, i always get the hd joints from napa with the fittings but even then the fittings are almost impossable to get to with the truck on the ground so i pull the shaft every summer and grease them up.
  3. #13
    Apr 2009
    So yesterday, I was backing out of my spot in front of the garage, and when I put the truck in reverse, it hesitated, then felt like it slipped with a bit of a pop. Definitely thinking it's that slip yoke. Transmission works great in every gear but that has happened with reverse a couple of times now.
  4. #14
    Sr. Engineer FergusonT's Avatar
    May 2010
    Southwest Michigan
    Yeap, I get a "clink" in reverse almost every time....so Shibby, you said you paid $250 for the yoke...seems like I read or heard that it was more expensive. Thats not bad.
    1999 Chevrolet Suburban LS K1500
    1991 Chevrolet S10 4.3L 4x4
    2005 Suzuki Forenza (GM/Daewoo)
  5. #15
    It was in 09 and i was still working in the shop then so i got a small discount. They were around $450 when the TSB first came out but they have come down. List was only like 40$ off what i paid but agian this is 3 years ago.
Similar Threads
  1. Nickel plated slip yoke to prevent the dreaded clunking noise
    By brentsmith36 in forum GM Powertrain
    Last: 05-06-2013, 11:15 AM
  2. Rear Yoke?
    By SuburbanSS in forum GM Powertrain
    Last: 12-16-2009, 09:55 AM
  3. What to Grease on GM Truck
    By ccpotter in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-22-2009, 07:31 AM
  4. Need grease?
    By 1st Synthetics in forum 1st Synthetics
    Last: 03-22-2009, 07:24 PM
  5. Nickle Plated Slip Yoke?
    By APX in forum Lifted & Offroad Suspension
    Last: 10-20-2008, 07:49 PM
