    Default white sulfur smelling smoke from under the hood
    Hello, I have a 97 Chevy Silverado 5.7 ...sometimes when I try to start it it just shudders and a white smoke comes from under the hood and then I can start it. Any ideas??? thanks in advance---Bryan
    Master Mechanic SupplySgt's Avatar
    Feb 2010
    Middle TN, displaced Okie
    Check your idler pulleys. Make sure they're not locking up and rubbing away your serpentine belt. After that, check your wiring. Any shorts will start burning away the sheathing for the wires in small increments. Not sure what color smoke it would put up but white smoke isn't out of the question, and it doesn't smell that great when it happens. Those are the first two things that I would look at.
    93 Suburban (Southern Slayer): TBI 350, 4L60E
    73 Z28 Camaro: L82, TKO 600
    KJ4CLI
    "...Death smiles at us all, all a man can do is smile back..."
    When you say it "shudders", do you mean it turns over, starts for a second and dies? It it back firing? Does it Just turn over? Given the info we have now, I agree with Supplysgt, I would check wiring. Especially near the starter.
  1. white sulfur smelling smoke from under the hood
    By bniland in forum Chevy Truck Talk & GM News
    Last: 06-26-2012, 08:48 PM
  2. 1995 350 white smoke, w/ oil in the intake manifold
    By young101stAB in forum Member Introductions
    Last: 08-17-2011, 08:20 PM
  3. 1990 silverado fuel injected white smoke
    By diastiss in forum Performance & Fuel
    Last: 07-10-2011, 11:03 AM
  4. 94 Suburban 6.5 Diesel White Smoke
    By Papi325i in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 02-26-2010, 02:00 PM
  5. 99 Express 3500 white smoke, milky oil [Expired Topic]
    By Flashvan in forum Chevy Express Forum (GMC Savana)
    Last: 01-14-2009, 08:05 AM
