    Default Fuel pump on the 8100 vortec again...
    So I have heard that the 8100 vortec had some fuel pump issues and my truck's problems point to needing a new fuel pump. So I will be needing a new fuel pump. My question is should I order another on from GM or is there a better aftermarket company I should go with?
    ---------- Post added at 09:33 PM ---------- Previous post was at 09:29 PM ----------
    Here is a link to another post of mine where I show you the spark plugs after just 6months of use.
    http://www.gmtruckclub.com/forum/showthread.php/87871-Bad-Fuel-Pump-on-the-8-1-Vortec#axzz1sp4xFzKM
    LB7|2" lift|20" rockstar xd's|wrangler mud tires|Leer cap|4in turboback|volant CIA|boost increase valve|EFI by DTS|phantom gauges|6 speed ZF-6|solid mass flywheel|ceramic Kevlar clutch|High idle switch|55 gallon in bed fueltank|Edge insight|4 rigid dually|app radio 2|250watt kicker amp an 10" sub
    I would go with any trusted aftermarket pump over a stock one from gm. It'll save you a ton of money and like you said they had problems with these stock pumps. I just replaced mine this winter. Just one tip I learned is when you get a new pump make sure it comes with a new wiring harness/connector because the stock ones have been known to have caused problems as well!
    2006 Duramax LBZ
    Edge Evo
    4'' Diamond eye to 6'' tip
    Lots of work left to do!
    ^^THAT! I went with 2 GM ones when mine went out and wound up having the 2 GM ones go out 2 weeks apart from each other. My brother ordered an aftermarket pump (can't remember the name) and as well as a connector. Has been fine ever since.
    ---------- Post added at 10:50 PM ---------- Previous post was at 10:49 PM ----------
    This was in late late 2010 I think
    Current:
    Future:
    Quote Originally Posted by ntbush83 View Post
    What company did you go with?
    ---------- Post added at 09:49 AM ---------- Previous post was at 09:48 AM ----------
    Thanks guys for helping me out on the issuse I found out what I was looking for.
    I went with a napa fuel pump. I have never had a problem with napa brand products.
  1. Bad Fuel Pump on the 8.1 Vortec?
    By Jason2325 in forum Chevy Truck Talk & GM News
    Last: 04-16-2012, 09:26 AM
  2. Replies: 0
    Last: 02-01-2012, 08:50 PM
    Last: 01-25-2012, 09:20 PM
  4. 8100 Vortec 5W30 only?
    By 572ysc in forum GM Powertrain
    Last: 01-30-2009, 12:59 AM
  5. Replies: 0
    Last: 07-29-2008, 01:49 PM
