Results 1 to 10 of 17
    Apr 2008
    Lexington, SC
    Default no back up lights
    On my 03 Avalanche one of my back up lights stopped working. So i bought new bulbs. The old bulbs didnt look blown so i tried them in the tail lights and they worked. I checked all the fuses and they were good. Also when i changed the bulbs i changed both sides and now neither one will work. Some how i did get them both to come back on for a little while when i was testing the socket with a test light. Some one told me to look at the circuit board but i really dont know what do with it. Why do we even have a circuit board? How do i tell if the board is bad andhow bad is it to change out? If anyone knows anything about this please help. Thanks.
    2003 Avalanche 4x4 with cladding 110k miles +, K&N stock replacement air filter, Skyjacker 8000 shocks, Hawks LTS pads, Summit Racing brand drilled and sloted rotors, Sylvania ZXE high & low beams, leveling kit, 285/70/r17 Michelin M/S
    This is the factory lights right? Check the socket. Alot of Avalanche owners have had problems with them coroding. Are you the first owner?
    Apr 2008
    Lexington, SC
    I am the second owner. The sockets appear to be in good shape. Anderson yes it is factory.
    And you said with the Test light it works fine?
    Apr 2008
    Lexington, SC
    Tested the test light ong the battery before and after to make sure ot works
    Did you test the leads by the socket? (the wires)
    try to flex the circuit board a little while they are on. See if they intermittently come on and go off. If they do, the board has either a broken trace or a cold solder joint.
    Apr 2008
    Lexington, SC
    I tested just the inside of both of the sockets. I was kinda short on time. It will be thursday or friday before i gwt to work on it again. Just wanted today seee what else i need to check. Sorry for the misspelled words my mobile web wont let me fix them for some reason.reading
    So, let's not get this problem overly complicated.
    Before you took it apart, you had one side working, one side not working..........................probably a bulb.
    You took both side apart and now neither side works...............probably using the wrong bulbs, or a blown fuse.
    Quote Originally Posted by freddie View Post
    Don't ya HATE when that happens?! I even have that problem on my iPad... It decides to alter words I type in. (that's why every single one of the posts I make from my phone or pad have been edited)
  1. Back up lights don't work
    By Magadith in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 08-03-2011, 09:45 AM
  2. New Back-up Lights
    By groceryman in forum Chevy Truck Accessories
    Last: 05-18-2011, 06:02 PM
  3. No back up lights!!!
    By mwolfe25 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-25-2010, 07:09 AM
  4. Back up lights
    By Rlee in forum Chevy Truck Accessories
    Last: 01-31-2010, 12:52 PM
  5. no back up lights... 90 suburban
    By scotsdale in forum Audio, Video & Gadget Tech
    Last: 10-26-2009, 07:13 PM
