    Apr 2012
    Bancroft IA
    Default 92 k1500 350 tbi
    Hey everyone I have a 92 k1500 350 tbi it runs fine down the road. However when at a stand still it acts like it wants to die when you stand in the throttle it also does this when you stand on it while driving. have done a complete tune up minus the fuel filter. When i adjusted the timing I noticed it looked like one of the injectors was not spraying fuel as well as the other. Thank you for any advice or direction with this issue because it is keeping us out of the mud...
    You adjusted the timing... Did you disconnect the computer control wire before adjusting it? First things first, you have a weak injector. that will make it run bad. get that taken care of. Then, it is a good idea to change the filter. I would be willing to bet a nickel that the injector will fix 'ya.
    Jan 2012
    Sault Ste. Marie, Ontario Canada
    I agree. Bad injectors can cause a lot of problems. If the difference in pattern is that noticable at idle it is time for a major cleaning.
    Bill Johnson over at http://www.mrinjector.us ultrasonically cleans, tests and rebuilds your injectors using an ASNU flowbench machine, provides you with a flow report and resistance test for your injectors -- for $16.00 each. He also includes the metering gaskets and injector o-rings. He's got this running thing of throwing in a few Jolly Rancher candies with every order. Really nice guy to deal with. Works fast, and typically has a 1 day turn-around time.
    I have no association with Mr.Injector other than using his service to clean various injectors for me. For a full cleaning and rebuild of any working injector.. its a hard price to beat.
    My lug nuts require more torque than your Honda makes.
    Apr 2012
    Bancroft IA
    Replaced fuel filter and had to readjust the timing runs great up until the speedo started bouncing...
    try disconnecting both battery cables, then touching the cables together.
    this will dischage all voltage capasiters and clear the computer's memory.
    my speedo with also bounce once in a while, i think its from being abrupt with electical dissconnections & reconnections without dosconnecting the battery first.
    also, you should throttle body clean out the intake with a spray, seafoam, or fuel addative (or everything) to ensure no gum build up, now that you just installed a new fuel filter too.
    it always seems to run happy after doing that.
    Apr 2012
    Bancroft IA
    Thank you did the sea foam trick truck just loves it. i will let try the the battery cables today.
  1. 97 K1500 oil pressure
    By dsquared in forum General Chevy & GM Tech Questions
    Last: 08-28-2011, 08:56 PM
  2. 97-98 k1500 dash compatable with a 95 k1500?
    By Lifted_Bowtie in forum General Chevy & GM Tech Questions
    Last: 12-11-2010, 04:51 PM
    Last: 07-30-2010, 07:00 PM
  4. 88 k1500 5.7-should have so much more
    By JohnnyC in forum GM Powertrain
    Last: 07-26-2010, 07:53 AM
  5. My K1500
    By SledHead in forum Photo & Video Gallery
    Last: 07-12-2009, 07:33 PM
