    Default On Board Battery charger?
    I have an Auxiliary battery installed in my truck. I havea 2009 Chevy Silverado 1500. I'm running dual optima yellow top's. Out where Ilive we have hot freaking summers 105+ and 10 degrees or less is easily scenein the winter dead batteries are common. Batteries donít last that long. I havea battery solenoid type battery isolator that is activated by a switch wired tomy dash. I have been looking into an on board charger. I have checked out acouple different 12v to 12v on board 3 stage charging systems. Has anybody hadany experience with these types of systems? Does anybody have any recommendations?
    I don't understand; is your alternator failing to charge both batteries?
    Former Member
    Apr 2012
    Reading, PA
    Quote Originally Posted by chevytrucknutzo View Post
    If it were me, I'd be looking into a marine charger that would do probably less than 5 amps...as was previously noted, unless your charging system is faulty or you have a significant drain on the system when the truck is off; you should be starting you "charging" with fully charged batteries, and just maintaining them. I would also look into battery blankets...to help keep them warm in winter. The marine chargers are weather tight, vibration proof, etc...perfect for under hood.
    Optima batteries are not a good choice for a starting battery in my experience...from what I've seen, a good auto battery like a Deka will last longer and start harder than an Optima. I had factory dual batteries in my Cummins, it saw every state in the contiguous US; and every type of weather from -30*F in the Rockies and feet of snow to 115*F+ in the Texas panhandle to hurricanes. Those were Deka batteries, they were over five years old and had well over 150k on them when I traded that truck...they never missed a beat in all that time.
    I would probably inspect the charging system first, look for a ignition-off draw, then suspect the batteries...
  1. Porta-Jump battery charger - Review
    By Steve in forum Product Reviews
    Last Post: 06-07-2011, 08:33 AM
  2. Replies: 0
    Last Post: 11-28-2010, 07:46 AM
  3. Trickle Charger
    By KAHruzer in forum Chevy C/K Truck Forum
    Last Post: 12-12-2009, 08:08 PM
  4. ATI pro charger ?
    By azdrtdog in forum Performance & Fuel
    Last Post: 04-07-2009, 05:48 PM
  5. Super charger ??
    By doc762399 in forum Performance & Fuel
    Last Post: 08-04-2008, 11:50 PM
