    Default Tail lights come on for no reason - 2005 Silverado 2500HD
    Brake lights come on for no reason. Thought it might be neighbors garage door opener triggering it but that is not it. Anyone with same issue and, if so, how do you solve it? Driving me crazy. Did it while out of town and neighbor called me. Finally went out. Thanks. Ron
    I would check your brake switch by your brake pedal. I have seen those go bad and cause some weird issues. The contacts may not be separating far enough and a slight temperature change may cause the metal to move just enough to close and turn the lights on. After it warms up from the current flowing thru it could reopen itself and turn the lights off. With the last one I played with, I removed it from the truck, popped the case open, and bent the metal that the contacts are on back alittle. That was 2 years ago and it still works fine.
    Pikey - Thanks for response. Looked last night in that area but wasn't sure what I was looking for. Released emergency brake, fooled around with wires in area and lights went out. Not sure what I did but at least I know where to look. Will look for brake switch and replace or repair, as you did. Is the switch at top of brake pedal? Been a long time since I have worked on something like this. Thanks again. Ron
    just follow the lever for your brake pedal up and there should be a sensor mounted to a bracket next to the brake pedal. It will have a little plunger that goes in and out when you step on the pedal
    Mud Truck
    1984 Chevy K5 Blazer
    -454 Edelbrock V8
    -33" BFG Mud Tires
    Daily Driver
    2006 Chevy Silverado K1500 LT Z71 - 5.3 V8
    -Bull Bar
    -Step Bars
    -Flowmaster 40 with dual tailpipes
    -Smoked Tails
    Blazer454 -
    Thanks. I am going to figure this thing out with good replies I am getting. Got a cool ready to get me thru process. Thanks again. Ron
    PS - Nice mud. Bet that was fun getting all that on there.
  1. Chevrolet : Silverado 2500 2500HD 2005 chevy 2500HD silverado pickup truck
    Last: 04-11-2010, 04:12 AM
  2. 99 00 01 02 Silverado/99-05 Sierra Red LED Tail Lights
    Last: 02-05-2010, 09:50 PM
  3. 99 00 01 02 Silverado / 99-05 Sierra LED Tail Lights CH
    Last: 02-05-2010, 02:40 PM
  4. aftermarket LED tail lights for 2005 GMC stepside
    By NKL&DIME in forum Chevy Truck Accessories
    Last: 10-06-2009, 06:59 PM
  5. Trading My Stock Tail Lights for Euro Tail Lights
    By ippielb in forum Chevy Truck Accessories
    Last: 07-10-2009, 11:50 AM
