    Default Jet mass air flow sensor
    Is it worth buying ?
    I was just talking to my buddy (mechanic) about my first stage on my 08 Silverado. That is part of the plain. With a cold air, exhaust, programmer. He said it was a must. On the other hand, I have see people say it is not. My guy has worked on all my cars for 12 years and has built some sweet race cars. So, me myself will be getting one. When it is time.
    I copied and pasted you title of post in the search engine on the top right of the page. Some posts come up that it is just mentioned and some were they are talking about it. You will just have to shuffle through it. Hope that helps.
    Tim Walters (Curky)
    I Have never use the Jet MA, But generally dealing with LS Fbodies. You don't gain enough to warrant the cost. I know of atleast 20 cars making over 500 rwhp on stock MA. IMO I think you money would be better spent on upgraded injectors and a dyno tune. Now if you had the Fast LSXR-T 102mm intake and TB, maybe, but on the stock setup it's a waste of money.
    I too have heard it's a waste of money, unless you are doing a serious build (500+hp) I would stick with the factory.
    2006 Silverado Crewcab 5.3l, has a modified airbox with drop-in filter.
    Mods to come:
    Exhaust
    Tune
    Suspension
    More power!
    I have a granatelli "tuned for CAI", and noticed some noticeable on acceleration, but it always threw a lean code. Granatelli told me I needed the one that corrected that problem. I have the stock box back in now with it and it doesnt throw a code. you may see a little performance from it. As stated before may be most usefull if fully decking out motor with TB injectors etc, but the stock one flows well. truth be told the granatelli is a stock MAF sensor with the middle bar cut out and tuned a little.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  1. mass air flow sensor bad?????????/ where is it located?
    By jteuban in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-21-2011, 10:43 AM
  2. Will a bad mass air flow sensor throw a code???
    By KuttingEdgeInteriors in forum Performance & Fuel
    Last Post: 02-21-2010, 10:16 AM
  3. Mass Air Flow Sensor Problems
    By chevyman1297 in forum General Chevy & GM Tech Questions
    Last Post: 09-25-2009, 07:10 PM
  4. need advice on performance mass air flow sensor
    By thekingsphance in forum Performance & Fuel
    Last Post: 11-24-2008, 11:02 AM
  5. Mass Air Flow Sensor
    By andrejj in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 09-13-2006, 02:34 PM
