    Default Trailer/Tow function won't engage
    04 Yukon, 185k. Pulled the boat out of winter storeage last weekend. Hit the trailer/tow button and nothing happened, no light, trans didn't shift, nothing. I pressed the button a few different times, nothing. Not sure if this is related, but I had the carrier bearings replaced in the front diff earlier this spring. Any relationship? I searched around here and didn't see much. Maybe a bad wire in the column? Anybody have any ideas?
    Quote Originally Posted by Tommy Panfish View Post
    Tommy, as you mentioned, what's most likely happened is, the Wire that runs from the Tow Haul Button, down the Shifter and then down the Steering Column and then down to the base of the Steering Column and overtime the Wire will get Pinched and/or Frayed, and then finally Break.......Here's a Picture of where the Wire is located, at the base of the Steering Column,
    There are two Very Small Gauge White wires inside the Orange sheathing..........to fix it, just stripped the wires back, twisted together and then soldered them back together and you should be good to go.
    Apr 2009
    If that does not work, a new shifter costs around $106. I've been thinking of trying to apply something to the wire itself to help make it a little more durable.
    2005 Chevy Silverado W/T
    Planned mods not in order
    I agree with what both Mike and Jimmeh have said. When you solder the wires back together, I will warn you that it may not stay together the first time. Because the wires are so fine and they kept breaking, I had to solder them back together 4 times over the course of a couple years when those wires broke on my Silverado
    Thanks fellas. I'll take a look this weekend and report back. Perfect pics....I really appreciate it.
    Nov 2008
    Endicott, NY
    Probably should splice them back together with a crimp splice Vs soldering. Solder takes away flexibility and makes the wires easy to break again.
    Bill
    Well...I finally took the lower dash apart.......pulled the sheathing back and the wires look good. Connections look good. Pulled the connection apart. Checked for power and I have 13 volts coming out of the pig tail that the wires plug into......so now I'm guessing either the connection is bad or something is disconnected or bad up in the shift arm itself. Before I go and buy a new shifter, does anybody have any ideas?
    on my side, effectively i found a cut wire, so i weld it together and the TOW HAUL button is working again thaks guys
  1. heater not switching function
    By renegade1957 in forum The Coffee Shop ~ Chit Chat
    Last: 02-20-2012, 08:03 PM
  2. How does the auto 4wd function
    By dabel in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-30-2010, 08:52 AM
  3. Headlights function
    By cdvntx in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 06-04-2010, 10:37 PM
  4. Dash function problem
    By park7163 in forum General Chevy & GM Tech Questions
    Last: 09-21-2009, 02:36 PM
  5. tow/ haul function
    By henrys021500hd in forum General Chevy & GM Tech Questions
    Last: 08-19-2009, 09:24 PM
