    Default 2000 Tahoe diesel conversion.
    Hey everyone.. I have heard of people doing engine swaps to a
    4BT Cummins for the tahoes, Has anyone here heard of this?
    are there better options? What would be the cost in something like this?
    Thanks for the help!
    Apr 2009
    I have never heard of this swap, but would be interested to see a build thread!
    2005 Chevy Silverado W/T
    Planned mods not in order
    Not worth it in the end. It will take too much money, doing through the electrical, drive line, and so on. You'd be better off to sell the tahoe, and get a diesel crew cab truck and put a topper on it.
    www.youtube.com/ippielb
    ^x2 you would have to change over the entire fuel delivery system and maybe even the tank. Along with the engine you would need the tranny for it as the standard tahoe tranny wont handle it. the computer to match that engine and tranny, then you would need new driveshafts as the stockers wouldnt be strong enough and most lokely the right length. heavier rear end and front end if 4x4. better suspension and brakes to handle the extra weight. unless you got custom built axles and gears you would be using some kind of stock axles which then would be 8 lug so you would need new wheels and tires as well.
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    down here in corpus theres a guy who dropped a cummins in a 92-99 tahoe. i work at discount tire and he has brought it in a few times and ive seen it on the highway too, that thing sounds mean! definitely one of a kind
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    There is a guy in Florida that puts the duramax in older tahoes and suburbans. He wants about 20 thousand to do it. That is all electrical, trans, motor, fuel delivery, and new rear axle. I think the company name is duraburb . Just google it.
  1. Diesel conversion video
    By Pikey in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 05-02-2012, 04:45 PM
  2. HID Conversion Kits for a 2000 Silverado LS
    By PantheraUncia in forum Lighting Discussion
    Last: 12-24-2011, 12:16 PM
  3. HID Conversion Kits for a 2000 Silverado LS
    By PantheraUncia in forum Chevy Truck Accessories
  4. Chevy Kodiak Super C Diesel Truck Conversion Motor Home
    Last: 06-22-2010, 05:20 PM
  5. Detroit Diesel Conversion Help
    By 91BigRig in forum GM Diesel & DuraMax
    Last: 02-23-2010, 06:34 PM
