Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
  1. #21
    This may help you determine if its the switch....
    http://www.thirdgen.org/cruisecontrolfix
    Get the Gorilla!
    gorilladip.com
    sales@gorilladip.com
  2. #22
    no didnt have to adjust nothing.
  3. #23
    Jr. Engineer
    Dec 2008
    south florida
    UPDATE...... FINALLY.
    ok guys, i finally got around to digging deeper into fixing my cruise control.... still no luck.
    i installed my new brake light switch, and let me say, the engineer who designed this style of switch is an absolute fool.( cant say how i actually feel ). it took me 90 minutes to get the old one out and the new one in... what a real pain it was.
    got it in and got it adjusted..... but it did NOT fix my cruise control problem.
    i need some more help.... here is what i have as of now..
    i checked the 4 wires coming from the cruise control switch it seems to me to be good ?
    key on=blue wire hot
    cruise on=green wire hot
    press set/decelerate=brown wire hot
    press accelerate=yellow hot.
    so, all 4 functions on the switch are working, so my problem should not be the switch, correct ?
    kw70chevy said his problem was the "electro motor cruise control " box under the hood on drivers side firewall. should i try that next ?
    i took the cover off that box and it all looked new inside. checked the 7 wire plug that press fits onto the box, and all i have is one terminal that is hot when the key is turned on, and another terminal that is hot when i press the "set/decelerate" button. i could not get a terminal to go hot when i pressed the accelerate button, and i didnt check to see if one of the terminals would got hot when i pressed the brake pedal. (i just thought about that).
    any thoughts on what i should check or try next ?
    i might hit the local junk yard tomorrow on my way home from work to see if they have a control box that i could try out...
    thanks for any help guys... i really want my cruise con
  4. #24
    Jr. Engineer
    Dec 2008
    south florida
    update..... i now have my cruise control back to working... it was the cruise control switch afterall. i was checking the 4 wires right after they came out of the switch, when i should have been checking them at the end of the harness.... thats where i found that two of the 4 wires were not good, probably broken somewhere in the middle due to the tilting action of the column over the past 22 years....
    autozone wanted $139 and napa wanted $219... i got mine at rockauto for $45....
    thanks guys... onto the next project
  5. #25
    I was right again!...haha ...glad you got it working again!
    Line-X Bed Liner
    Factory Black Running Boards
    BF Goodrich All-Terrain KO's
    2" RC Leveling Kit
    EGR Vent Visors(In-Channel)
    Exterior PLUS Package
    K&N Drop-In Air Filter
    OEM Mud Flaps
    Next Planned Mods
    Dual Exhuast
    Black Bowties
  6. #26
    Jr. Engineer
    Dec 2008
    south florida
    Quote Originally Posted by ChevyBoy2009 View Post
    yep, you nailed it from the start...... thanks for your help man, i really appreciate it... until the next project
  1. cruise control not working
    By skimm99 in forum Member Introductions
    Last Post: 01-05-2011, 08:08 AM
  2. Replies: 3
    Last Post: 12-03-2010, 06:40 PM
  3. Cruise control stopped working on my 2007 Silverado - no warranty left
    By Sportmod5 in forum General Chevy & GM Tech
    Last Post: 11-01-2010, 10:03 AM
  4. Engine light linked to Cruise control not working? Help!! please?
    By Rhizzlebop in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 08-16-2010, 09:20 AM
  5. Cruise Control not working
    By leadpan101 in forum Audio, Video & Gadget Tech
    Last Post: 03-30-2009, 09:21 AM
