Results 1 to 10 of 11
    Default 2001 Suburban Z71 rear diff locked up
    A friend asked me to look at his 2001 suburban, Z71 with 250k miles that just violently stopped in the middle of the road while doing 35mph on a city street. He had it towed to his home and is now sitting in his driveway.
    I am planning on looking at it this weekend. He is not sure which one is locked up. He thinks it could be the rear end.
    Any suggestions what to check first?
    1993 964
    1996 318TI
    I would pull the diff covers and check the condition of the fluid and check for metal shavings. Or you could jack up the truck and put on jack stands and check to see if the tires rotate.
    Thanks Aloxdaddy.
    I only have the small 3-ton jackstands. Will they be safe enough to hold the suburban and creep under the it?
    Do I have to put the transmission in neutral?
    3 ton jack stands should be fine. I think thats what I have.
    Current:
    Future:
    Check the rear brakes before you open up the diff, not unheard of for a set of shoes to break loose and cause this type issue.
    thanks. I'll check that out too.
    I put the rear on jack stands and checked the diff today. Nothing unusual or broken. Drained the fluid first and there was no metal shavings, then removed the cover and inspected the ring and pinion while the transmssion in neutral while spinning the wheel. The ring and pinion gears were fine and i did not see any broken teeth.
    I may have to inspect the rear parking brakes first before i go to the front diff.
    It locked up while driving in 2H. If the rear diff is fine, what else could cause the truck to stop like something locked up? In 2H, the front diff spins together with the front drive shaft, right? Could it be the transfer case?
    We are lost.
    How is the tranny acting? Our '02 had a "safe mode" issue a couple of years ago, where it only ran is 2nd or 3rd, I think. If the tranny locked up, that'll stop everything attached to it.
    Good luck,
    1999 Chevy K2500 Suburban 350
    I had a problem a few years ago, it seems that my brake fluid had water in it and when the calipers would get hot the water would expand from the heat and apply the breaks. after it would cool down the breaks seemed just fine. After flushing the break system with new fluid the problem went away.
    Ford has a better idea! Drive a GM!
    07 GMC Sierra Classic
    07 Honda Accord EX-L
    68 Camaro (blown)
    2011 Ford F550 V10
    I don't own this truck, I just drive it!
    Quote Originally Posted by KidHauler View Post
    Good luck,
    Thanks, the thing is, I ran the engine while the rear was on jack stands, then I put it in drive, the rear wheels turn and did not lock up. I reved the engine to 2k rpm and the wheels spun faster and did not lock up. I also applied the brakes and did not lock up anything.
    Today, I will check first the parking brakes for any broken parts that could lock up the wheels, then raise the front on jack stands and check the front diff.
    ---------- Post added at 07:04 AM ---------- Previous post was at 07:03 AM ----------
    Quote Originally Posted by giorge View Post
    Thanks, i think I will flush the brake system too as it has never been flushed.
  1. Locked up diff? is this a Torsen? Can I rebuild it?
    By CaptnPea in forum GM Powertrain
    Last: 02-01-2012, 11:52 AM
  2. 1996 GMC suburban 1500 rear diff
    By ozjock5050 in forum GM Powertrain
    Last: 11-07-2009, 02:50 PM
  3. Rear A/C suction line, 2001 Suburban
    By gklane8850 in forum General Chevy & GM Tech Questions
    Last: 06-24-2009, 12:52 PM
  4. 2001 2500 vs 2001 2500HD. whats the diff
    By Castor Troy in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-29-2009, 07:07 PM
  5. 2001 4x4 Suburban 1500 locked or open diff
    By BajaDiver in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-04-2007, 02:13 PM
