GM Truck Club
Results 1 to 5 of 5
    Default Violent Shaking in Wheels felt in my stering wheel
    My 1997 Chevy Tahoe 4X4 LT 5.7 Recently began to have the front wheels shake violently and as well as have a whining sound coming from my wheels as I turn them. They do not shake all the time but sometimes the shake becomes rather violent. It looks like I might have a leak coming from my powersteering resevior, would that cause my wheels to shake like that? its only been shaken since Saturday evening, I didnt drive it much sunday but experienced today on the way to work.
    typically front end shake is going to come from a couple of areas.
    warped rotors
    warn front end suspension parts (idler, pitman, ball joints etc)
    Tire balance (whether it be balance or tire belt seperating)
    David
    2004 Silverado 2500 Crew Cab 4x4, AMSOIL EA air filter, Granatelli MAF sensor, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST) and 4.10 gears, Rhino Liner, EGRUSA fender Flares and widow visors, extended stainless steel brake lines, firestone airbags w/onboard air compressor, Pioneer Avic X940BT navigation, Accel backup camera.
    http://www.gmtruckclub.com/forum/sho...Silverado-2500
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    2013 Toyota Avalon Limited (Wife's Car)
    NRA Life Member
    X2 on tire balance.
    The wine you hear when you turn maybe just a low level in the power steering resevoir.
    Its called "death wobble" lol
    its why i sold my jeep and said no more solid axle ever again.
    on our trucks with individual front suspension it can only be a few things.
    does your truck have a lift?
    usually it can be contributed to (in order of cheapness to fix)
    sway bar
    shocks
    A frame bushings
    Axle bushings
    wheel bearings
    CV axles
    basically that wobble means your front suspension is shot.
    Gas was $1.83 when Obama took office.....
  5. #5
    Quote Originally Posted by K15 Blazer Guy View Post
    sway bar
    shocks
    A frame bushings
    Axle bushings
    wheel bearings
    CV axles
    you know the 97 doesnt havea solid front axle right?
    i agree that it could be a tire problem. iv seen broken belts cause a nasty "wobble", iv also seen them cause more of a shake, are you in a place wehre you have snow and could there be snow/mud in a rim (cuasing them out of balance)? in fFWD cars iv seen worn tierod ends cause a shake, its pluasable taht a loose steering componant will cause a shake as well.
    "i dont think you got the picture. i got a beautiful picture. this baby happens to have an extra turn of speed, which is the only thing i care about. you dont understnad what happens do you? they make cars. they make 'em exactly the same way. one or two of 'em turn out to be something special. nobody knows why. i know why. i may be kiddin' myself, but i think i can make somethin' out of that sad little bucket of bolts." ~ Tennessee Steinmetz
Similar Threads
  1. shaking or vibration coming form the steering wheel
    By silverado0596 in forum General Chevy & GM Tech Questions
    Last Post: 01-20-2010, 10:39 AM
  2. my stering wheel is lose?
    By 1995z71 in forum Lifted & Offroad Suspension
    Last Post: 09-14-2009, 10:46 PM
  3. Aftermarket wheels cause shaking
    By 08SierraZ71 in forum General Chevy & GM Tech Questions
    Last Post: 08-24-2009, 02:34 PM
  4. Stering Wheel noice?
    By iPublicEnemy47 in forum GM Powertrain
    Last Post: 06-09-2009, 06:18 PM
  5. Violent Tornado Rips Through U.S. Midwest Killing Nine People
    By Cableguy in forum IL - Illinois Chevy Truck Fans
    Last Post: 05-06-2007, 08:47 PM
