Results 1 to 2 of 2
    Default knpck sensor problem?
    Can any tell me where the knock sensor-s are on a 1999 express van 4.3 v6? Thanks gritsboy
    Quote Originally Posted by gritsboy View Post
    On my old 4.3 it was located on the trans mounting flange portion of the block below the oil pressure sending unit. To change it requires removal of the distributor then the oil pressure sending unit then unscrewing the sensor and pull it out.
    So in other words, its at the back of the intake manifold.
    HOWEVER; this is info from when I changed it on my 97 Silverado. I'm not sure if its in the same location as with the van. I'll see if I can dig up a picture of the location.
    Current:
    Future:
  1. oil pressure sensor problem?????????????????
    By 4.8chevysilverado07 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-22-2012, 10:17 AM
  2. Engine code: P0121 TP sensor or APP sensor 1 problem
    By mah2496 in forum GM Powertrain
    Last: 11-04-2011, 11:38 AM
  3. 99 5.3 silverado fuel tank pressure sensor problem
    By ChevEE in forum General Chevy & GM Tech Questions
    Last: 12-02-2010, 12:26 PM
  4. Sensor problem ?
    By boots1882 in forum General Chevy & GM Tech Questions
    Last: 06-13-2009, 01:48 PM
  5. 2004 2500HD O2 Sensor Problem
    By richard309 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-08-2009, 02:56 PM
